Comprehensive Opti-Coat 2.0 Application Guide
Todd@RUPES
Just a regular guy
Optimum Opti-Coat 2.0: How To
NOTE: Video added to end of post. 7/27/12
Opti-Coat 2.0 offers a high-gloss protective clear resin coating, similar to the clear coat that already exists on your vehicle, only better! Optimum Opti-Coat 2.0 can be applied to all exterior surfaces. Unlike wax and sealant coatings which will wash and wear away, Opti-Coat 2.0 provides superior protection that lasts-wash after wash- day after day- year after year.
Optimum Opti-Coat 2.0 can be applied to the following exterior surfaces:
  • Painted (both single stage and clear coat)
  • Headlights
  • Wheels
  • Bumpers
  • Aluminum & Chrome Surfaces
  • Trim
Much like clear coat protects the paint underneath (which in turn protects the primer that protects the body material), Optimum Opti-Coat 2.0 provides protection for the clear coat. Opti-Coat 2.0, when fully cured, is extremely hard and scratch resistant. The thin layer of Opti-Coat 2.0 itself is highly resistant to UV rays, acidic and caustic compounds, and resists surface attachment by foreign material. Your car will enjoy the following benefits:
  • More resistant to surface scratches such as swirl marks and wash marring
  • Much greater resistance to acid damage from polluted rain, bird bombs, and insect residues
  • Improved resistance to light abrasions such as fine rock chips and road blast
  • Release and shed dirt, grime, and road pitch much easier, making washing easier
  • Resists contamination reducing the need for claying
  • High levels of UV protection to reduce sun fade
Optimum Opti-Coat 2.0 was modified slightly from the original professional formula. (The pro version is still available under the Opti-Guard name.) Optimum Opti-Coat 2.0 cures more slowly, which gives you more time to apply the coating correctly.
Directions:
  1. Prepare paint by cleaning, claying, and polishing to remove any paint defects. Once Opti-Coat 2.0 has cured you will not be able to polish any defects that remain unless you remove the Opti-Coat 2.0 first.
  2. Clean the surface with a paint cleanser such as a 15% or stronger solution of Isopropyl Alcohol (IPA) or dedicated stripping agent.
  3. Prime the applicator by making an X pattern across the pad. Only a few drops will be needed for each subsequent application.
  4. Wipe Optimum Opti-Coat 2.0 onto a single panel at a time in a thin layer using two directions, in a circular or front to back direction.
  5. Within 5 minutes, inspect the panel with adequate lighting looking for any thick areas (high spots) that have not flashed away to clear.
  6. Use the foam applicator or a paint safe microfiber (A Gold Plush Jr. Microfiber is included in the Opti-Coat 2.0 Kit) to even out any areas where you see thick areas or streaks. Note: This step is key, as any spots not leveled will have to be polished if allowed cure. Panels will feel a bit tacky and will be self-leveling during cure time, so avoid any unnecessary touching, wiping, or contact to produce the best results.
  7. Repeat steps 1-6 for each panel where application is required.
  8. Allow to cure for 24 hours with out exposure to the elements.
Surface Prep
Since Opti-Coat 2.0 forms a permanent coating over the surface (that can only be removed by abrasion such as paint polishing) any paint defects will be sealed in after the coating cures. Wash and dry carefully, then clay thoroughly to remove any bonded contamination that could affect surface bonding. Take your time and polish the paint to remove any paint defects. Make sure that you are satisfied with the paint condition before moving forward with application.
To prepare this Porsche 911 Turbo the paint was carefully washed with Optimum Car Wash and clayed with Pinnacle XMT Speed Clay. Then it was polished using Optimum Hyper Compound Spray using a Meguiars Microfiber Cutting Disc with a Griot's Garage 6 Inch Orbital Polisher. This aggressive polishing step was repeated until we were happy with the surface condition. Then the paint was polished with BLACKFIRE SRC Finishing Polish using a 5.5 Inch Lake Country Hydro-Tech Crimson Pad, again with the Griot's Polisher until gloss was maximized.
Clean
Machine polishes, clay lubes, and almost any product that touches of the surface of your paint (including your finger tips) contain oils or lubricants that may interfere with Opti-Coat 2.0's bonding. In order to ensure the best results and easiest application the paint should be free of all chemicals. You can use diluted IPA or a chemical stripper.
I prefer CarPro Eraser Intense Oil & Polish Cleanser. It is a blend of slow flashing alcohol and surfactants that make it easy to remove any offending oils with out streaking. Mist CarPro Eraser on the panel, spread with a soft microfiber cloth, then immediately flip the cloth over and buff dry before any residues can re-deposit. Because CarPro has a long-flash time it is more forgiving then traditional alcohol, plus the added lubrication adds some protection against accidental marring.
Setting Up
Optimum Opti-Coat 2.0 ships in a package that includes:
Start by unscrewing the black cap from the Opti-Coat 2.0 syringe. Don't loose the cap as it you will need it to re-seal the Opti-Coat when you are done. (There is enough product supplied to fully coat 2 or more vehicles.
Screw on the supplied blue Syringe Tip.
Application
Apply Opti-Coat 2.0 to the foam applicator by pressing on the plunger in the syringe. For your first panel draw a thin X across the pad. For subsequent panels apply a few drops.
After applying an X, I like to fold the applicator on itself and spread product to as much of the bare foam as possible.
Now wipe on the panel in two directions, spreading a very thin coat over the panel. For example apply up and down, then side to side, or in a circular pattern followed by side to side. Note: Larger panels such as hoods should be split into halves.
Opti-Coat 2.0 will initially leave a fine film of product behind. Note: Optimum Opti-Coat 2.0 should be applied indoors; the following pictures where taken outside are for reference only. (The outside lighting better shows the application)
Optimum Opti-Coat 2.0 will look oily upon application.
It will quickly begin level, appearing to 'melt' into the paint as it flashes off. These pictures are taken 5 seconds apart.
High Spots
As you can see from the above pictures, Opti-Coat 2.0 is self-leveling and very easy to apply. However some areas may have thick areas of product that appear as dark splotches or streaks. These high spots must be removed before Opti-Coat 2.0 fully cures.
Inspect the paint in adequate light 5 minutes after application, looking for any areas that have not self-leveled during this time period. In the pictures below I purposely over-applied the product to create visible high spots.
You have up to 20 minutes to remove high spots from the paint. Lightly buff them away with a microfiber towel or smooth them over with the foam pad.
Repeat the previous steps, applying Opti-Coat 2.0 to, and removing high spots from, a panel at a time until the entire vehicle is coated. Remember you can apply Opti-Coat 2.0 to wheels, trim pieces, coated & uncoated metals, and headlights. Avoid direct exposure to the elements for 24 hours if possible.
Here are pictures of the black Porsche 911 Turbo after Opti-Coat application.
After Care
Optimum Opti-Coat 2.0 is like a wax, paint sealant, and clear coat on “performance enhancing supplements”. It excels at increasing your paint's resistance to chemical, environmental, and sun damage while increasing it's dirt shedding ability. However it is not the end-all be-all of paint care. In order to keep your paint looking great you should still care for it.
Follow the following tips to keep your Opti-Coat 2.0 and thus your paint looking great.
  • Opti-Coat 2.0 dramatically increases your paint's resistance to acid rain, bird bomb damage, bug damage, and chemical spills, however it is not impervious to them. If something is strong enough to chemically eat into and damage paint it will likely damage or remove the micro-thin Opti-Coat 2.0 (given enough exposure time). While you may have considerably more resistance (and thus time) to remove harmful chemicals from the paint, care should still be taken to do this.
  • Wash your car carefully, using the two bucket method, a quality wash mitt, and dry with a soft microfiber drying towel. Opti-Coat 2.0 will dramatically increase your paint's resistance to wash induced marring but it will not make it impervious. The increased hardness offered by Opti-Coat may completely eliminate wash induced marring if the safest techniques are used.
  • Opti-Coat 2.0 still needs to be clayed, just far less frequently then cars that use traditional waxes and paint sealants. The contamination will also be much easier to remove with a mild clay bar due to Opti-Coat 2.0's contaminate shedding ability.
  • While you can wax or add a paint sealant over Opti-Coat 2.0. the reason for doing so would be aesthetics only. For the same reasons that contamination has a hard time sticking to Opti-Coat 2.0, so does waxes and paint sealants. There is very little microscopic texture for waxes and paint sealants to grip onto. Applications of Optimum Instant Detailer & Gloss Enhancer or Optimum Car Wax will keep the Opti-Coat slick and looking great for a long time.
Questions or Comments on Opti-Coat 2.0 application encouraged.
[ame="http://www.youtube.com/watch?v=nvj80cB2HLc"]Opti-Coat 2.0 Application - YouTube[/ame]
Todd, this writeup is more then amazing and should be the "definitive how to" for Optimum Opti-Coat 2.0....:bigups
Great write-up Todd! Thanks for sharing!
Is the resin's hardness the same between Opti-Guard and Opti-Coat 2.0? The only difference is the flashing time?
Also, what's the shelf life of OC2.0? Is it indefinite provided that you screw back the black cover piece after you're done using it? If it's not indefinite, what are the signs that the product is bad?
Todd,
Thanks for the great write up you are the Man!
This would help a lot of people with little experience on Opti Coat!
I m wondering if anyone have ever tried to apply OC with a 4 inch pad and DA? While we still prime pad and apply product to pad like we do for foam applicator, will DA make OC applied more evenly?
Dennis P.
Very nice write up Todd.
I prefer to use the CarPro Foam block & Suede MF as my applicator. I feel like it absorbs less and gives me a little more control of application.
Another trick I have learned is to transfer a small amount of OC/OG into a 2oz sprayer nd use that to mist the applicator. This seems to work much better to cover the entire face of the applicator and ease the use verses using the syringe. Also when I spray the applicator I spray towards the panel I am working on. That way any overspray ends up on the panel and I can spread it out.
This has no ill effects on the coating when you put it back to the syringe?
Using a small spray bottle was actually suggested to me and others by Chris@Optimum.
When putting the coating back into the syringe there is an easy step to take. Pour the remaining coating into a small cup (like a medecine cup) and then use the blue tip to suck up all of the coating. I then turn the syringe vertical with the tip face up and push all of the air out. Then replace the tip with the black plastic cap. Since OC/OG is air cured and actives the less air in the syringe the better.
To this point I have had no problems. And everything has worked out well. Transferring the coating to a spray bottle for me is so much better and easier than "fighting" the syringe.
Awesome write up on applying OC2.0. Mr Raskovich over at DI and also the Optimum guys said that the OC2.0 can be layered up to ~4 times within ~30 days (full cure time to achieve max hardness). Have you found this to be true or even attempted?
As far as using the spray bottle application, being a newbie to detailing, I would not suggest doing this unless you are very familiar with the coating. My face tends to be very close to the surface that I am applying OC to, and atomizing the product means you definitely need full face protection; you don't want to breathe, coat your nostrils, mouth, throat, and lungs. As Todd said this is an indoor application and spraying could get tricky/dangerous.
Using a DA to apply would also, in my mind, be a bad idea. The higher friction and heat produced may greatly reduce the leveling/self leveling window.
Just my $.02
My understanding is the results (hardness, shine, protection) are identical between Opti-Guard and Opti-Coat 2.0
I think shelf life is going to be variable on how much air is allowed to react with the Opti-Coat. I still have the original Opti-Coat from 2 years ago and it works great, but I am careful about exposing it to air. (More on this in a second).
That said I have a friend who received the original Opti-Coat around the same time and his hardened to a solid piece of resin.
Here is how I keep from exposing the contents in the syringe to air (benefits of being a diabetic). There is a small amount of air in the syringe to begin with. Keep this air. When you squeeze the Opti-Coat 2.0 from the syringe do it with the plunger side facing up. When you invert the syringe the air bubble will naturally travel to the top (against the plunger). If it doesn't, flick the syringe with your finger (this is why you see nurses do this before they inject a shot).
Keep some Opti-Coat 2.0 in the tip at all times. When you are done with your application point the needle side towards the sky. The originally air bubble will now travel towards the top to the tip (which is still filled with fluid that has been exposed to outside air). Now push a small amount of your original air bubble out to clean any exposed fluid from the tip. Now remove the tip with the screw on cap and you are done.
Todd,
Dennis P.
Thank you Dennis.
I have not applied Opti-Coat with a DA polisher, but I have thought about for testing purposes. I am sure, when I have the time, I will give it a shot. I will make sure to report back.
great write up todd. i really like the look of the finish.
I have heard people say (mainly the guys from Optimum) that it doesn't add too much to the surface in terms of aesthetics, but I feel like it gives the paint a glossy wet look as do a lot of people who have used it.
Thanks for the info Todd! :rockon
So long as the solution hasn't hardened to a resin then it should be good to use right? Do you have a picture that shows us how it should look like when the resin is beginning to harden? Also, so long as you fully screw in the black cap then the syringe is completely sealed off from the air outside?
So when you transfer OC2.0 to a spray bottle, put the unused portion in a cup to be sucked back into the syringe, won't the solution have already reacted with air?
Great write up Todd!
I've for Eraser to be my go to wipe-down product as well. I also agree with Troy on the CarPro block wrapped with the suede MF towel for application...for most surfaces anyway. Plastic trim, wheels, and door jambs seem to work best with the supplied foam.
I feel it gives the paint a "glassy" look.
I've only used the 2.0 on one car, but with Opti-Guard, on a warmer days I'd say you have less than a minute to knock down high spots...IME at least. I'll likely be using the 2.0 this weekend with temps in the 90's. ;)
Rasky
