wascallyrabbit
so does anyone have and approximate release date?
wascallyrabbit said:so does anyone have and approximate release date?
David Fermani said:After giving Dr. G an update with my finding he mentioned that because his pads are a tiny bit smaller than the Meg's pads
Picus said:More stuff to buy!I personally found the megs finishing pads cut just as well as the cutting pads (same material I think?), last longer, bog down less, etc.. I just ordered like 40 more, all finishing discs.
Deep Gloss Auto Salon said:From what I have read, the mf in both finishing/cutting discs are the same but the foam is different?
I can't wait to give these a whirl.
Picus said:More stuff to buy! :x I am glad to see more mf pads also. RE: cutting vs. polishing, I personally found the megs finishing pads cut just as well as the cutting pads (same material I think?), last longer, bog down less, etc.. I just ordered like 40 more, all finishing discs.
RaskyR1 said:The MF material IS definitely different between the cutting and finishing discs.![]()
Deep Gloss Auto Salon said:Thanks for the info Rasky....
I've never used the finishing discs, which is why I made sure to preface with "From what I have read".
The top and sixth are SUR BUF (we may start carrying these too), 4-5-9 are polishing, and the orange ones are cutting pads. You will need to use our backing plate as some velcros will not release the pads well and they can come apart with too much effort.
