rlmccarty2000
Active member
I’m continuing to work my way through the new wave of coating SiO2 based toppers. Some say they can be used as stand alone last step products (LSP), that is up for discussion.
Here are today’s victims
This is the test hood. It has been rinseless washed with McKees N-914, clayed with Primo Slick clay lube and Nanoskin fine clay substitute. The same as all my previous tests.
The hood was broken down into thirds. Each product was applied by spraying a microfiber towel and applying to the hood as recommended by the manufacturer. Left to right in alphabetical order was GTechnique, Hydrosilex, and IGL. Nice and shiny!
Here is the mandatory beading shot using distilled water.
Thoughts: All three products went on nice and easy, wiped off clean/easy with no streaks. The IGL Premier surprised me by being noticeably rougher (not slick) than the other two or any of the other SiO2 topper products I have used in any of my tests.
Budgetplan1 has generously said he would send me some Kamikaze Overcoat to test, so I will do one final test with it versus two Polish Angel toppers I have then I will write up my final observations of all the SiO2 topper type products I have tested.
If anyone has a product I have missed and would like it included pm me and I will see what can be done.
Sent from my iPad using Tapatalk
