brianrich said:Yes indeed. The Honda ENGINE will last but what about the pump and it's innards? Do some more homework on the PW's and you'll find out that it's not just the engine that's involved.
tdekany said:In the store they only had Karchers. That is what I bought. $160
tdekany said:I read the reviews of the Task Force 2000 PSI 1.6 GPM Electric Pressure Washer on lowes .com. Worst reviews ever. I almost went to get a unit based on what you said above, but I can't do it now reading all the terrible experiences people are having with it.
bkoz said:If you read the reviews on any of the PWs on that site you will see most of the problems people were having were leaks and silly problems like soap dispenser not working. If brass quick release fittings were used, no more leaks. If they read the instructions they would have realized the soap only dispenses when using the low pressure setting. I read the reviews before I bought the unit and determined most of the complaints were questionable, so I took a chance. I agree with some of the better reviews that most people don't even read the instruction or have never used a PW. One of the complaints is that the pressurized water only comes out in a pinpoint pattern; if they read the instructions they would have realized you have to turn the end of the nozzle to change the pattern to adjustable fan pattern that works GREAT. This unit also stops if there is a little air in the water supply. Again, if you didn't read the instructions you would think the unit is broke. I recommended this unit based on many years of using other brands and my experience with this one. I have not had ANY problems with this unit and I use it regularly for car washing, concrete, patio, block walls and siding cleaning. Everything worked fine. You have to take a good look at reviews and balance out the good/bad and determine how bad the bad reviews are.
Koz
robortjack said:The Snap-on brand stands for best quality products, best-in-class service, innovation, expertise, premium price, productivity and status. Through a comprehensive licensing program with Alltrade Tools, Snap-on, one of the most prestigious tool brands in the world, is being integrated into multiple aspects of the DIY enthusiast's and professional contractor's life.
