We have used quite a bit of the 105 here in the shop--just finished my first qt. I have used it on Audi paint (super hard), Porsche, C6, fesh paint (10 days old), old Honda paint, and a few others. Aside from the gumming issues when using foam pads, which is there is a remedy for btw, it is by far the best compound that I have used via rotary.
With a foam you must use *very* little, not "optimum little", but very little. Working the product too long, or having the pad loaded will result in gumming up. I recently purchased a LC system 2000 pad cleaner--I simply wash my pad every other panel and all is well. As others have stated, it cuts *quick.* Don't expect to work it like SIP, 106FF, OP, etc as you will dry buff or gum up the product.
IMO, it is best via a twisted wool pad in that it seems to *not* gum up, or at least not as easily. With a foam pad it will remove significant marring while leaving a very nice finish. On vehicles with severe to moderate defects (for customers paying for a two-step) I use the purple LC foamed wool pads. IMO, this is the best bang for the buck with this product--all of the cut, the increased cut (over foam) of the wool, yet it finishes out beautifully. Move to your final polish of choice and you are set.
Thank you Meguiars for making the product that we have been longing for! Now if you guys could reformulate the rest of your line using the same technology, I would be in heaven.
BTW, if you guys aren't using the W66 BP with the foamed wool, you are missing out!
