Pro detailer in Portland, OR
tdekany said:
The car was put on a truck last night and should be here soon now. I'll call you later today.
PS: You WILL remove more clear with sanding than with the most aggressive polish/pad, no matter how "soft" the sanding paper is.
tdekany said:
I should have been more specific, I meant if somebody sat on a scratch with a rotary with a heavy compound, instead of sanding and then post-sand polishing more efficiently. See what I'm getting at?
Similar to the test that TH0001 completed a year ago, between different machines and techniques. The goal was to compare which method removes the most clear.
Remember that one? He compared a PC to a rotary, and sanding/rotary. It's a good read. I sure wish that I could find the link, though.
