has anyone used any of these?
Mothers Professional Products
Mothers® Professional Rubbing Compound quickly removes 1,500 grade and finer sand scratches from all types of refinish and factory applied automotive paints. May also be used to remove light oxidation, car wash scratches and other defects from paints that do not require sanding. #81132, 32 oz.
Mothers® Professional Heavy Duty Rubbing Compound quickly removes 1,200 grade and finer sand scratches from all types of refinish and factory applied automotive paints. May also be used to remove heavy oxidation, car wash scratches and other defects from paints that do not require sanding. #81232, 32 oz.
Mothers® Professional Foam Pad Polish is recommended for removal of compounding swirl marks from all types of refinish or factory applied automotive paints. Also recommended to enhance color and add depth. #83432, 32 oz.
Mothers® Professional Machine Glaze is a high-quality polishing glaze that quickly removes compound haze, fine scratches and swirl marks from all types of refinish or factory applied automotive paints. #82332, 32 oz.
Mothers® Professional Hand Glaze is recommended for added shine and protection and may be used after Mothers® Professional Foam Pad Polish to achieve unparalleled depth and clarity. Hand Glaze is easy-to-use and completely safe on all types of paints. #84532, 32 oz.
