Melt away brake dust
Here is a pic of an alloy wheel that was contaminated with brake dust and tar. See the top half of the wheel (the before) and the lower half? (After). I used a new product that literally melted the tar and brake dust from the wheels. It is a solvent based solution of Limonene and surfactants (emulsifiers)The nice part is it is non-petroleum base, and not caustic. This product is concentrated and needs to be mixed with water to activate it. Ratio of 4/1 part water. its made by Ardex. Gary Perfectautofinish.com
This stuff should only be mixed as you need it, has a shelf life of 3 weeks when activated with water. I just sprayed it on, and used a small detail brush and scrubbed it clean.
Would some Dawn soap/water mixture do just the same? That's what I use and it looks to do just the same as what you've posted.
