mobiledynamics
Some mullings/musings on LED bulbs in housings not originally meant for LED.
The many LED design of the bulbs have come a looooong way. Some now are good for backups as far as (throw) is concerned.
Canbus does work - turn off cold check, adjust PWM settings, resistors/caps - the usual you need to do if putting in a LED bulb....
I think the answer is not universal. Sometimes I think a LED bulb for example in a turn signal, may be too Bright in a housing. May look fine in the day but driver blinding at night
