exile
Corvette Z06/85 jeep CJ7
You know, I went to the link for the vacuum and from the information provided was not able to determine if this would work at all as an extractor. The water in the vacuum seems to be to retain dust as it passes through the system, and water extraction isn't mentioned, I don't believe. If I were you I would go to the local grocery store or Walmart and rent a carpet cleaner. Twenty bucks and you'd have it done, and done probably as good as you can get it.............Tom
http://rugdoctor.netsuccess.com/cleaning_products.aspx
