Cleaning my cam cover
imported_perry
My engine bay has been neglected for several years now. No excuse really, just laziness. I've used CD-2 a couple times, and Simple Green a few times, other than that, not too much.
But now I'd like to really clean things up. Dunno why, guess I'm bored and this should keep me busy for a while. :nixweiss
4 or 5 years ago, I tried painting some highlights on the cover using engine paint and was never really happy with how it came out. I removed the paint using a small wire brush on my Black & Decker Wizard (cordless Dremel clone), which also seemed to kinda polish up the metal as well.
I doubt that it's a good idea to do that to the entire cover that way though. You can see a small area that I did in the top left to try it out, between the spark plug well and the long indentation. Does good, but I'm not sure that it's a good idea to do the entire cover that way. The lower left corner was done with Mother's Mag & Aluminum polish 7 or 8 times, took over an hour, and still doesn't look completely clean. Seems like it'll take forver to do the entire cover this way. I think the top center and left has had the polish applied once or twice. The area around the oil cap hasn't been touched.
Perhaps I need something more abrasive? Should I keep using that wire brush on my Wizard? I don't necessarily want it to be blindingly shiney, just clean. Any suggestions?
Once it is clean, how should I keep it clean in the future?
Well, a polishing wheel on a drilll works well. I suppose it might get it shinier than you want, but hey, what does that hurt. ;)
Hmm.. Doing some Googling. Sounds like a scuff polishing wheel is what I would need. I tried felt and it didn't do much good.
SCUFF POLISHERS/ABRASIVE BUFFS: Similar to Scotchbriteâ„¢, these are great for cutting through dirt and grime and leaving the base material with a nice satin finish. They also work well for light sanding. Use them on all kinds of metals, wood, glass, stones, and plastics.
Link
I'll have to check Lowes & Menard's to see what they have.
Only sucky thing is that I only have one battery for my Wizard, and it only seems to last like 10 minutes.
I spoke with my mechanic/cousin tonight, and he suggested wetsanding with 1000 grit, then a Scotchbrite type pad, then the Mother's polish.
I asked him about high temp clear, and he wasn't certain that something existed that would bond to aluminium. I'll have to look through the auto stores and see what I can find.
From my many years of restoring cars, I have found that using a clear paint on bare metal does nothing to stop rust or corrosion.
Eastwood sells a product called Diamond Clear made for aluminum, etc. I don't know how well it works though.
Another product for bare polished aluminum is made by Busch..and I think it's called Aluminum Wax. I used it on the diamond plate on my trailer as well as on some trim for the Plymouth and it does seem to slow the corrosion process.
