Migue
Might be easier to just remove the cowl piece to ensure better prep,coverage and avoid overspray. Overspray will reach areas that would surprise you. When i was prepping my car for full exterior paint, i did a small masking job around the areas where i was going to spray black paint to cover bare metal that had rust and was now removed, and there was overspray on the opposite side of the car! you couldn`t see it but you sure could feel it. The areas were much smaller than your cowl also, so imagine all the overspray spraying that whole plastic piece may create.
I`d check online for instructions so you can at least confirm whether it`d be easy to remove or not.
