DavidB said:I have used CA Water Blades for many years with no problems, even on black. I think if you follow two safety precautions you will be okay:
1. Wipe the blade with a towel after each pass, and
2. Only use the blade on a surface with plenty of water.
Every time I spoke with someone who claimed the WB caused damage, I discovered they were not wiping the blade or they were dragging it over a dry surface.
DavidB said:/..Every time I spoke with someone who claimed the WB caused damage, I discovered they were not wiping the blade or they were dragging it over a dry surface.
qwertydude said:I use the absorber and feel it's safer.
