John@Autopia-Carcare.com
1Z Einszett Anti-Insekt Bug and Tar Remover
:rockon
Product Description:
1Z Einszett Anti-Insekt Bug and Tar Remover is concentrated for effortless and protective removal of insects, tar, grease, bird droppings and other stubborn contaminates from paintwork, chrome, glass, rubber and plastic. With its unique solvent properties, 1Z Einszett Anti-Insekt + Pre-Cleaner easily cuts through dead insect remains and dried-on bird droppings.
This product does not contain enzymes and is therefore particularly gentle on skin. Anti-Insekt + Pre-Cleaner is bio-degradable, formalin-free and propellant-free.
Use 1Z Einszett Anti-Insekt Bug and Tar Remover as a spot treatment before washing. Rinse your car thoroughly, then spray Anti-Insekt + Pre-Cleaner on areas that require treatment. Allow the bug and tar cleaner to work for up to three minutes, then agitate with your wash mitt and wash shampoo.
16.9 fl oz (500 ml) Spray Bottle. Imported from Germany.
Environmentally friendly.
Cost $9.99
Tested this product on the front end of one of the employee's Honda.
Not totally trashed with bugs but plenty of Florida dead bugs.
Directions state to shake bottle well then to spray the area.
You should apply on cool surfaces out of the direct sunlight.
Nice thing is you do not need to wet the area first, which makes this a great product for traveling.
Spray the surface well for good coverage...
Allow to sit on the surface for no more then 3 minutes...
This stuff works fast.
Nice thing with the foam as it does not run off the surface too fast, allows it to work before dripping all off.
Just take a microfiber towel and all the bugs with gently wipe off.
It is truly amazing how easy this makes bug removal.
Here is a shot with the right have wiped down, you can see it took them all off with no effort.
Up close 50/50 shot.
This took no more then five mins to do the front end.
All I can say is Good Stuff, you should keep a bottle on you especially when you travel.
The bottle states it easily removes insects, sap, road grime and tar.
After using it I would say I fully agree! Totally worth the money great product, cannot think of anything bad to say about this product. Everyone should have a bottle in their trunk when they travel. And if you leave in Florida, grab one and to be prepared for the love bugs!:bigups
