What foam gun is everyone using?
GlossyTundra
Tractor Detailer
I am definatly in the market for a foam gun. They look wayyy to fun. It will be for my personal use, in my area you could not leave foam on a car that long dwelling, it would dry and spot. I have talked to Justin about the one he uses, but I want to see what others are using and how much sucess they have had with it.
I want mine to go on a pressure washer, but if it doesent, no biggie. I just really want tons and tons of foam, I will be using Duragloss CWC for shampoo. I looked at the autogeek one, but I have heard mixed reviews on that thing.
So what does everyone have in the way of foam guns?
BigAl3 said:
here's the one is use, and it's made by gilmour of course...
What shampoo do you use? What ratio do you mix? What is your cleaning process when using the Gilmour?
I just orderd the Foam Master II. It has a dial to adjust ratio. So I am curious how I should be using it properly.
Thanks.
accumulator, pointed out a good ratio. add 5oz's of car wash to a gallon water jug. if you want LOTS of foam, than just add your car wash straight into the container un-diluted...
p.s. i'm using the EO1 car soap (blue) as i got 15 bottles of the bucketless wash for a penny each, when autozone was discontinuing them...
I just got my Foam Gun from Autogeek.com and I tried it with my Poorboys car wash and I had it on the lowest foam setting and it worked pretty well. I am curious as to how people use the gun, do you just put soap in the canister or do you add the soap and fill it with water? Also is Poorboys a good car wash to use with the foam gun?
I use PBs Super Slick & Suds with my gilmour & it works great. I fill the bottle 90% full with warm water then top up with the PBs & give it a shake. Set the mix to 4 & off we go, loads of foam & easily enough to do a large saloon.
No problems, one of the things I love about the Gilmour is experimenting with different ratios, settings & shampoos. There is literally a perfect setting for every taste but it can take some getting there.
Still, it's fun seeing the neighbours faces if you overcook it & end up with foam drifting down the street. :grinno:
I'm looking to pick up a foam gun too, I am going to be using it on a regular hose, no pressure washer.... Is the Foam Master II the best thing out right now? I am looking to achieve the most foam possible.
if you want the most possible foam without a pressure washer, use straight soap in the gilmour (something cheap like NXT)
