Topping Poli-Sea. Glaze, Sealant, Wax??
TN9thSi
I am 90% finished claying and applying Poli-Seal on my Glacier Silver Mazda. So far PS has exceeded my expectations. It works in easily, doesn't dust, and wipes off like a breeze. The shine is pretty good. I am thinking about adding another sealant/wax on top to enhance the gloss and wetness. I thought about a glaze, perhaps RMG or one my other faves, DWG. If I glaze, what should I top it with? I have been using Werkstatt Prime Acrylic and AJT, but can I use this on top of a glaze? I'm really looking for the most wetness and slickest finish I can get with one or two more steps. I like to use OCW between waxing as well. Any suggestions on what to use next. I'll be finished with PS in about 45min. Does PS have a curing time?
I don't have an answer for your question but have also been thinking about doing Poli-Seal/RMG/Lusso Oro and was wondering if applying RMG over Poli-Seal would be ok.
I went ahead and applied DWG after letting PS cure for 30 minutes or so. Seemed to have worked just fine. The DWG left a noticeable improvement in gloss and wetness. What little flake is in the paint now pops and reflects in the sunlight. I doubt you will see a negative result when using a glaze on top of PS as long as you top the glaze with wax/sealant. Now I just have to find a good wax/synthetic sealant to top the DWG with. Maybe I'll just use OCW after every ONR wash. I've been doing that routine since before Winter and it has worked nicely. Or maybe I'll use Natty's or S100. I'm open to suggestions and to trying something new here.
That does look wet! I just finished my detail. I did: FPII on the hood to remove some marring, PS, DWG, finished off with OCW. Did Natty's on the front fenders just to experiment. Looks pretty darn nice. I'll try to get some pics. I may have to try AJT on the rest of the paintwork after seeing the pic.
Just did the Inferno Red Mag-wag this past weekend. Poli-seal applied via Cyclo w/blue pads topped it Sealed with Opti-Seal and topped with OCW.
Will do Nighthawk Black Acura TL this week. Plan to use Poli-Seal via rotary w/green foam waffle pad, glaze w/Pink Moose and top w/OCW. Did this same trio back in December and just now starting to see degradation in June. But I did maintain it with weekly ONR & Gloss Enhancer.
