removing front plastic piece from PC
2000firebird
i need to take the front black plastic cover off to i can fit the pc better into a tight spot i am trying to use it. how can you take this off without breaking it?
When I ordered mine in a kit a few years ago, that part was loose and it makes noise when I crank it up. I would also like to remove mine or figure out a way to tighten it down.
mine was loose also
so I went to a hardware store
and found 2 rubber washers, 2 flat washers
and 2 hex head cap screws
now it's tight, no more "rattle"
