Pbh ?
+1 PBH is going to remove your KSG. The only Glaze that won't remove your KSG are Danase Wet Glaze, Meguiar's #3, 5, 7, and 81.
Accumulator said:
GS4_Fiend- This isn't what you want to hear, but I'd correct the "buffer trails". No matter what. Those are simply something I wouldn't live with if only because they're a result of not doing the job properly.
Trying to hide them, by putting a glaze on top of your sealant, just isn't the right thing to do IMO. Just IMO though :nixweiss
GS4_Fiend said:
You are right. But for some reason why I used the Menzerna Power Finish on 4" LC Green pad, it doesn't do the trick for some reason. It absolutely removed the swirls but not the rids, some light scratches, and buffer trails if that's what they are..
Maybe the Power Finish *caused* the trails :nixweiss It's either too abrasive (and/or you're using it incorrectly) or it's not abrasive enough (use a more aggressive pad, or product, or just work on it more). Gotta be one or the other.
Sorry, I'm not being of much real help but I think you oughta find a solution that really eliminates them. I know it's a PIA, I sometimes spend forever trying a scad of different approaches (even though I've done this since forever and think "gee, I oughta have a quick solution!") before I find the correct approach.
I don't want my car to be an experiencing car. So imma stop polishing. It is a big pita when I polish. I tried PBH and wasn't too happy about it. It didn't hide the minor imperfections that I listed. Somebody told me RMG would do a better job?
What are your biggest problems when polishing?
The only thing that's a PIA about polishing for me is the cleanup (pads,cords, etc).
I've never used RMG but after looking at others reviews on this forum, it doesn't seem like it fills much. I would go with a heavy oil glaze and a nuba if I wanted to try and hide some stuff. I too though am with accumulator and think you should fix the problem instead of hiding it.
Don't really want to remove any more clear. Just a burden thing. I mean in the sun, it doesn't really look that bad. So I thought if I put on a Glaze, it would help hide but I guess it didn't work. PBH is a hype after all for being a glaze.
You know what Accumulator.. After giving some thought. I think that 3 layers of KSG is working pretty well. LOL. I think that's the wall that PBH couldn't break through. I basically applied it by hand. Maybe if I apply it by machine it could change the world? I ponder that.
