Pb Qd+
keesue
San Francisco Bay Area
I have read on another forum that QD+ streaks. It appeared to be the general consensus. I was wondering what the experienc is here as I am considering the purchase. I have Natty's Red, S&G, EX-P and QW. My experience with these products has been good.
Thanks in advance...
Just a fine mist will do, if one puts way to much then it will streak a little on you. Steve let me use it on my Mazda when i got to DFIII after my 3 1/2 hr drive there and i love it a lot. It needs a good shake and a fine mist and one is good to go.
As with most detailing products, a little goes a long way, I've heard. Does anyone know if QD+ can be diluted with water? I haven't used this product but if it's like a traditional QD it may be able to be diluted. Steve?
As said previously ...it only takes a very small amount and I suggest using a fine mist sprayer. Surprisingly even when you tell people less is better, they seem to go against what has been tested and advised:notme:
remember also that it contains wax, so it needs to be buffed ;)
THOROUGH buffing is needed after application. Finishes off nicely, though. Brought back a nice shine on a 2 month old finish I tried it on.
Sounds like a QD carrier with a spray wax...duh! Thanks for the input.
Amazing product. I have never had any problems with it. The shine it leaves has become my favorite among all my Qd's.
This has been very helpful input. This product appear to augment S&W S&G, meaning the one is used to clean, one is used for traditional QD and QD+ is a booster in between full waxes. Is this a correct assumption?
Yes S+W is for cleaning
S+G is a traditional QD with no protection
and QD+ will leave a layer of Wax as protection
I just got a bottle of this yesterday, of course within five minutes of receipt I was wiping down everything that had paint on it. :D I really like it, it made the paint on my truck look even blacker than it was before.
Just a little testament here. a couple of hours after I did my truck, my sister in law called wanting me to go pick up a piece of furniture for her, on the way I was attacked by a few bugs, when I got home they wiped right off :bow.......have never been able to do that before :bigups
Used for the first time this weekend. After a polish and sealant were down I used it as a wipe down the following day. It worked wonderfully. I sprayed it on, spread it around, wiped it off and then buffed it out after it hazed. It took a total of 4 MF to complete my Mazda Protege' 5. I found that a final buffing after completing the vehicle made all the difference.
Hey Pockets or Poorboy,
So based upon Pockets description, QD+ could almost be a replacement for Spray and Gloss? In other words, cleaning up my car with Spray and Wipe, sprucing up with Spray and Gloss and protecting with QD+ is over kill. Going straight from Spray and Wipe to QD+ will be fine.
yes it could replace S&G ..just remember the car should be clean and dry before using QD+ ;)
I'm not getting the hang of this stuff. I know it is good because everything I have tried from PB is exceptional!
Last weekend I waxed the car with Souvern Paste. Today I washed the car and then thought I'd try the PB QD+ again. I tried to spray lightly. Just one squeeze on the pump. I also shook the bottle up. I could see streaking and I had to really buff to remove the streaks and wax. I ended up using PB S&G to go over the hood.
What am I doing wrong? :inspector:
