opti-seal question...
stanger
last month i buffed and zainoed (z2/z5)my car, and i was wondering if i could apply OS over the zaino ? do you usually apply waz/polish and top with OS ?
stanger
Scottwax said:
Opti-Seal is totally compatible with Werkstatt, Zaino and cured carnauba based on my testing.
When you worked with it and JW, what was the JW products that used under it?
Scottwax said:
I've used it over Prime, AJ and AJT.
Hi Scott,
I use Prime and then AJT. In your opinion, is there a measurable change in appearance with the addition of OS? After appying OS, how would you freshen the finish between washes? Would you be inclined to apply another layer of OS or AJT?
Thanks!
Thanks, Scott! Honestly, I can't tell the difference between the 2 sides. For now, I guess I'll stick with AJT.
