NXT Question
#5 New Car Glaze
#5 New Car Glaze is a non-abrasive pure polish formulated to dry in humid climates. Unlike it's cousin #7, #5 New Car Glaze dries quickly and turns white. It contains no ingredients with the intended purpose of abrading paint.
If #5 New Car Glaze is removing swirls in your paint, then chances are high that it is acting as a lubricant while your application material is actually abrading the finish and upon wipe-off, the polishing oils are filling in what remains.
Because it dries, it tends to not make for a very good machine applied product because any heat generated while using it will tend to make it try to dry even faster.
But what the heck... if it's working for you, go for it, it's just there a much better products like a cleaner/polish like #9, #82, #80, #83 that are more suited for defect removal by machine.
By the way, #5 New Car Glaze is a product that came out in the 1950's for single stage acrylic lacquer and enamel paints, but you can use it on modern paints if you like.
I'm looking at the directions on an older bottle from the 1980's and the directions say in bold letters,
For hand application only
Mike
First of all I Will apologize for any misguided information I have given here.
Second of all I respect Mike Phillips's views on this subject, what the heck He been in this business a hell of a lot longer than I.
I'm still on a learning curve and I guess I just fell off.
Third Mike you should up grade your bottle of #5
Mine reads
"Method of application :
For use by hand, orbital buffer, D.A. polisher or rotary buffet.(Note: if using a rotary buffer be sure you are familiar with its proper use.)"
I guess that's where I got lucky.
THE END
Nuff said.
You know, I grabbed a bottle off my Antique Meguiar's Bottle Collection, instead of walking out to the garage and grabbing a current bottle when I wrote that.
Yeah my bad.
Still, #5 is fairly dry product, Thursday night at Meguiar's garage I'm doing a Before & After on an older Mustang, just for fun, I'll try a current bottle of #5 by machine.
Mike
