VIPERxGTx2000
mrecktid said:I'm glad to hear that it works. I'm really interested in this but I have several questions.
So instead of the $150 pump, we should use a pressure washer? Or do you mean we should get our own cheaper pump from like Home Depot?
How many gallons did you use?
Did you use the pump or a pressure washer?
How fast did it dry?
How was the ease of setup/install?
-Mark
I meant you should get a cheaper pump from home depot or lowes. If your pressure washer uses 1.5GPM(Gallons Per Minute) then you need to buy a pump that supplies at least 1.5GPM.
I did not wash or rinse off the whole car. He had gotten the car back from the dealership washed and waxed so I just poured a little of the tap water on the right of the hood and some RO/DI water on the left of the hood.
My pump didn't arrive yet so I am unable to use a pressure washer.
Drying time is the same as tap water. It depends on the sun and temp outside.
Setup and installation was pretty simple. Take out of box, make sure everything is tight(I skipped this step and got water everywhere when i started it), pop in the red tube which goes into the red hole on the system, pop in the green tube which goes into the green hole. Unwind the black tube(already connected) and lay it somewhere to drain the dirty water. Place green tube in the Brute trashcan which you should of gotten from home depot, along with the pump, and your done.
I also purchased the optional auto shut off and check valve. This attaches to the green tube and is attached to the trash can. When the water reaches the level you attached it to, it automatically stops the water flow so you don't have a mess.
