Hey guys,
Well I have the following products:
Porter Cable 7424
Sonus Acrylic Spritz
Sonus swirlbuster polish
Sonus swirlbuster foam polishing pad
Klasse All In One
Sonus SFX - 2 Enhance Pad
Klasse High Gloss Sealant Glaze
Sonus microfiber detailing applicators
And I was just looking for some confirmation / tips with some of the steps I will be using.
Step 1:
I will wash the car using the 2 bucket method, using the sonus microfiber wash mitt, and meguiars nxt generation car wash, drying the car with a sonus microfiber blue drying towel.
Step 2:
Next I will clay bar the entire car using a mothers clay bar / spray mist and clean off with a sonus towel as I go.
Step 3: (Should I use the sonus acrylic spritz with this pad? Just one squirt prior to layering on the product?)
I will use the sonus swirlbuster polish with the sonus swirlbuster pad on speed 4 / 5 / 6 ( I have some pretty stubborn swirlmarks that will not come out ). I will remove this with another sonus towel.
Step 4:
I will use Klasse All In One with the Sonus SFX - 2 Pad. I will spritz the SFX 2 pad prior to layering on the klasse all in one. How many coats of Klasse All in One should I put on the car? Do I only need one coat? And should I wipe off the residual haze / product after I have layered it on with the porter cable?
Step 5:
I will then use Klasse High Gloss Sealant Glaze, I will use the two sonus microfiber detailing applicators to wipe this on the car, and I was reading to only use a small amount of this product as it is very hard to remove? How many coats of Klasse High Gloss Sealant Glaze do you recommend?
I will then buff off all the Klasse all in one with the appropriate sonus towel (I can't remember their names but I have quite a few here lol..)
Now do I need any steps after using the Klasse all in one and Klasse sealant glaze?
Usually I would use meguiars nxt generation tech wax as my wax but I don't think I need wax using the klasse system?
I had previously used the Sonus SFX 1 - 2 - 3 Pad and Product system but I did not achieve the results I was looking for after spending around 10 - 13 hours on the paint, especially with removing swirls, it removed quite a few but not nearly as many as I had expected, so that's why I bought all these products and also the specialised sonus swirlbuster polish / pad system.
Any tips are appreciated! Thanks :bow
Porter Cable 7424
Klasse All In One
Step 1:
Step 2:
Step 4:
Step 5:
