Roger Koh said:Free samples are available for your testing!
Roger Koh
Leather Doctor®
Roger Koh
Leather Doctor®
judyb said:A lot of products are waster based but still contain oils or waxes in an emulsion. Oils/waxes etc cannot penetrate the finishes that are put on auto leather and stay on the surface where they collect more dirt to deteriorate the finish. The reason for using water based products is to keep the leather rehydrated. All leather has to transpire (breathe) which allows the movement of moisture particles back and forth through the leather so all surface coatings have to allow this to happen otherwise it is sealed and is not leather. Mositure particles from water based products are very fine (much finer than oils and waxes) and so can penetrate the finishes and rehydrate the leather.
True water based products do not contain oils and/or waxes so if the label says they do then don't use them.
There are many water based cleaners around some good and some not so good. Foaming cleaners are the best as they can be given dwell time unlike liquids. Cream cleaners are not good as they need to be 'cleaned' off after use!! making them a pointless porduct.
'Conditioners' are the products that cause the most confursion. Again they should not contain oils or waxes as this does no good for your leather finish. 'Conditioning' leather as far as a tanner is concerned is the moisture balance so using a true water based product will condition your leather in the correct way.
LM, Fenice and LTT all produce true water based products.
Hope this helps
JohnKleven said:1Z Leather Care is a water based emulsion. Works very well.
John
Roger Koh
Leather Doctor®
Hope this helps
John
Focus2069 said:Ok..now Im confused.
This is what I use:
Leather Cleaner Plus Conditioner Combo Deal 2 Step Solution For Restoring Old Leather (Leather Cleaner 16 Oz. & Pure Leather Conditioner 16 Oz.)
and I like it so far, smells great, and keeps it clean, but I dont want to be damaging my European Recaro Leather seats either...(seats are in a 2004 Ford Focus SVT, with the European appearance package, and you cant buy these seats anymore....)
is this ok to use??? Im so paranoid now..and I was planning on doing my interior tomorrow.
Roger Koh said:Yes these 3 cleaners and 3 conditioners are water-based!
And the fact that it is water-based also denotes that it has a pH value.
The pH value is either on the labels or found in the MSDS.
It is always better to double check with a pH meter or litmus paper.
Why?
User has to be cautious about ALKALINITY and SOLVENCY!
Alkaline water-based leather cleaner is not necessary safe for the leather structure if it is not neutralize to the pH neutral (3-5) of leather!
Alkalinity will streaks the leather finishes and result in tackiness that easily attracts soiling.
Alkalinity when comes in contact with the leather structure through the perforated panels and needle-holes will eventually stiffen the leathers and cause crack.
Alkalinity causes the protein fibers to shift anionic (-) and breaks the hydrogen-bond of the other anionic leather constituents (tanning agents, preservatives, fatliquors and dyestuff).
Water stains marks are common examples of alkaline exposure.
And it is not necessary that a water-based product does not contain SOLVENT.
Solvency dries up the fat and oils from the leather structure – that when dries and used frequent stiffen the leathers.
Solvency is good to emulsify oily or greasy soiling if the leather is non-absorbent, but it is bad when the wear areas becomes absorbent or the perforated panel absorb these solvency.
Therefore it is recommended to recondition the leather chemistry integrity with an acidifying rinse to pH balance to its pH neutral of 3-5.
Hydrating stiff and dried leather to plump it up with more breathing spaces relaxes and separates the inter-fibrillary spaces for more effective fiber lubrication by fatliquoring.
And replenish the fatliquor from drying up and leaching out thus rejuvenating it to its strength and suppleness for practical usage of compressibility, stretchability and flexibility with integrity.
Thereafter we talk can about the final surface conditioning of non-stick protection, buttery-feel, and leather-scent and how leather can be enhanced more sensuous and luxurious that charms.
A wise search is to request for samples and test it out!
Roger Koh
Leather Doctor®
