May 21, 2007 #1 I Imatk New member So I'm a little unclear as to the use of the Prime. Should Prime be used after a final polish like say Menzerna FPII or is it to be used before? Or if you're using FPII do you need to even use Prime? I will be using the Jeffs Acrylic jett and AG as well. Thanks for any help
May 21, 2007 #2 J joshtpa New member Use it as you would use any AIO. To me, I would put it on after polishing and before the LSP.
May 21, 2007 #3 M Milestones New member yeah I would go: 1) clay 2) true dedicated polish (like Menzerna FPII) 3) Werkstatt Prime 4) Werkstatt AJ
