Here's you go:
Carpro Tradng Ltd. Safety Data Sheet according to REACH Regulation (EC) No. 1907/2006
Product: Iron-X Revision date: 06/04/2011
Version: 1.02 Issue date : 11/04/2011
1/6
Section 1: IDENTIFICATION OF THE SUBSTANCE/PREPARATION AND OF THE
COMPANY/UNDERTAKING
Identification of the
substance or preparation
Iron-X
Use of the
substance/preparation
Non-corrosive Iron Removal
CarPro Trading Limited
Address 7 Lfigeneias 4th Floor strovolos, Nicosia 1687 CYPRUS
Telephone +972 546 411 911
Company/undertaking
identification
Email
sales@Cquartz.com
Emergency telephone +972 546 411 911
Section 2: HAZARD IDENTIFICATION
Harmful
Harmful if swallowed
May cause sensitisation by skin contact
Section 3: COMPOSITION/INFORMATION ON INGREDIENTS
Substances classified as dangerous according to Directive 67/548/EEC, if present (individually, or
in combination) in concentrations exceeding those defined under 1907/2006.
Name EC Number CAS
Number
Content
(% W/W)
Hazard
Symbol(s)
R-Phrase(s)
Ammonium Sulfanylacetate 226-540-9 5421-46-5 3-25 T R25, R43
Alkyl Ethoxy sulphate -------------- 68585-34-2 1-15 Xi R38, R41
Additional substances, listed according to 648/2004
0.1% or more but less
than 1%
Fragrance
2/6
Section 4: FIRST AID MEASURES
Inhalation If patient feels unwell, remove from exposure and keep warm and at rest. Ensure airways are
clear and give oxygen if breathing is difficult. If symptoms persist, seek medical attention.
Contact with skin Wash the affected area thoroughly with soap and water. If redness/irritation develops/persists,
Contact with eyes Immediately irrigate with eyewash solution or clean water. Medical advice should be sought as
a precautionary measure.
Ingestion Wash out mouth and dilute ingested chemicals with plenty of milk or water. Do NOT induce
vomiting. Seek medical attention.
First aid facilities: Eyewash and normal washroom facilities.
Advice to doctor: Treat symptomatically.
Section 5: FIRE FIGHTING MEASURES
*****This product is not flammable*****
Extinguishing media Foam, carbon dioxide, dry powder or water fog.
Hazardous
decomposition
products
Thermal decomposition giving flammable and harmful products: Hydrogen sulphide,
methymercaptan, ethylmercaptan, sulphur oxides, carbon oxides
Special fire fighting
measures
It is advisable that fire-fighters wear self-contained positive pressure breathing apparatus and
full, chemical proof, turnout gear.
Section 6: ACCIDENTAL RELEASE MEASURES
Personal precautions Suitable personal protection should be worn whilst dealing with spillage/accidental release.
Refer to section 8 for further details.
Environmental
precautions
Wash spillage area with water to dilute. Do not discharge into natural waters without pretreatment
at a water waste/sewage/biological processing plant.
Small spills (<5L) May be washed down the Methods for cleaning drain with water
up
Large spills (>5L) Should be contained with absorbent material and disposed of
professionally.
Notification: If this material enters the waterways, contact the Environmental Protection Authority or your
local Waste Management Authority.
3/6
Section 7: HANDLING AND STORAGE
Handling As with all chemical products, eye and skin protection are advisable if repeated exposure or
splashing may occur. Use in a well a ventilated area and avoid inhalation of vapour or mists.
At all times, observe good hygiene and working practices i.e. wash hands prior to eating,
drinking, smoking or using toilet facilities.
Storage Store in original, closed containers, in a cool (20°C), dry and well ventilated area. Avoid
sharp edges and other potential sources of puncture. Ensure product is stacked safely.
Avoid: Carbon steel, copper and copper alloys.
Section 8: EXPOSURE CONTROLS/PERSONAL PROTECTION
Occupational
exposure limits
No occupational exposure limits listed (EH40 – UK Health and Safety Executive) for
hazardous components listed in section 3.
Ammonium Sulfanylacetate:
INRS (FR) 2006 VME 1mg/m3
ACGIH (US) 2007 TWA 1mg/m3
Hand/Eye/Skin
Protection
Hand, eye and skin protection should be worn if repeated exposure or splashing may occur.
Contact with skin should be minimised, In case of spillage, rubber boots and PVC suit should
be worn.
Respiratory
Protection
Not normally required due to low volatility. However, if the product is being used in an
enclosed area, respiratory protection is advisable.
Section 9: PHYSICAL AND CHEMICAL PROPTERIES
Appearance: Colourless Liquid
Odour: Characteristic
Freezing Point: Not available (aqueous liquid)
Boiling point: 100 °C (same as water)
Flash point: Does not flash
pH: 6.5-7.0 @ 20°C (pH Neutral)
Relative density: 1.08 g/ml @ 20°C
Solubility: Soluble in water in all proportions
Section 10: STABILITY AND REACTIVITY
Stability Stable under normal conditions.
Materials to avoid Strong oxidising agents, nitric acid
Conditions to avoid Excessive heat (more than 50°C) and cold. Direct sunlight.
Hazardous reaction
products
4/6
Section 11: TOXICOLOGICAL INFORMATION
Acute toxicity: LD50 (oral, rat) 170-650 mg/Kg (adapted from OECD Guideline 423 (Acute Oral
toxicity - Acute Toxic Class Method))
Inhalation: Low risk – not volatile.
May cause irritation to the mucous membrane and upper airways. Symptoms of exposure may
include sneezing and coughing.
Skin: Low risk.
May cause irritation and sensitisation when in contact with the skin. May result in redness and
itchiness.
Eye: Low risk.
May cause irritation in contact with the eyes, which may result in redness, stinging and
excessive tearing.
Ingestion: Medium risk.
May cause nausea, vomiting and possible abdominal pain.
Section 12: ECOLOGICAL INFORMATION
Ecotoxicity LC50 500mg/L (adapted from OECD Guideline 203 (Fish, Acute Toxicity
Test))
Persistence and
degradability
Easy to eliminate.
Biological degradability > 90%
Bioaccumulative
potential
Does not bioaccumulate.
Other adverse effects None
Section 13: DISPOSAL CONSIDERATIONS
Dispose of according to relevant government regulations. Empty containers should be rinsed with water prior to
disposal or recycling. If necessary, quantities greater than 5 Litres/Kilograms should be treated by a professional
disposal company.
Section 14:
TRANSPORT INFORMATION
UN Number Proper shipping name
Hazard
Identification
number
Class
Packing
group
Land
transport:
ADR/RID
Not classified as dangerous for transport
5/6
Sea transport:
IMDG
Air transport:
IATA/ICAO
Section 15: REGULATORY INFORMATION
Hazard symbol(s)
Harmful
Contains Ammonium Sulfanylacetate. May cause an allergic reaction.
R-phrase(s):
R22 Harmful if swallowed
R43 May cause sensitisation by skin contact
S-phrase(s):
S2 Keep out of the reach of children
S26 In case of contact with eyes, rinse immediately with plenty of water and seek medical advice.
S37 Wear suitable gloves
S46 If swallowed, seek medical advice immediately and show this container or label
Guiding information:
This product is classified, labelled and packaged according to the Chemicals (Hazard Information and Packaging for
Supply) Regulations (United Kingdom) 2009 and to the Approved Classification and labelling Guide (Sixth Edition).
Additional reference has also been made to EC Directive 67/548/EEC (Dangerous Substances Directive) and
conformity with EC Directive 1999/45/EC (Dangerous Preparations Directive) has been checked.
The surfactant(s) contained in this preparation complies(comply) with the biodegradability criteria as laid down in
Regulation (EC) No.648/2004 on detergents. Data to support this assertion are held at the disposal of the competent
authorities of the Member States and will be made available to them, at their direct request or at the request of a
detergent manufacturer.
The information within this data sheet has been collated from EC regulation 790/2009 (amended 1272/2008), the
CESIO recommendations for Anionic and Non-ionic surfactants (2006), the EH40/2005 Workplace Exposure limits, the
Detergent Ingredients Database (DID-list, maintained by Ecolabelling Norway on behalf of the European Commission),
CESIO recommendations for the classification and labelling of surfactants as “Dangerous for the Environment�,
REACH Registered Substances Database IUCLID5) and from ingredient safety data sheets.
The data should be considered when making any assessment under the Control of Substance Hazardous to Health
(COSHH) Regulations.
Section 16: OTHER INFORMATION
Full text of hazard symbols and R-phrases, if mentioned as hazardous components in section 3.
R25 Toxic if swallowed
6/6
R38 Irritating to skin
R41 Risk of serious damage to eyes
PLEASE NOTE: the above risk phrases refer to the full strength ingredients, NOT to the Iron-X product.
Revision history:
Revision Author date notes
1.02 BL Scientific 06/04/11 MSDS updated to REACH specification. Classification according to DPD
and CHIP.
If you have any queries relating to this MSDS, its contents or any other safety related questions,
please write to:
sales@Cquartz.com
The information contained herein is believed to be accurate and is given in good faith. No warranty
or guarantee is implied. Recipients must take responsibility for observing existing laws and
regulations.
Reply Quote
