imported_jgv
What kind of tests can I do to compare the abrasiveness / cleaning power of common products, like for example how can I tell if a cleaner has mild abrasives or it's just chemicals?
Any ideas?
Any ideas?
jeremyp111 said:just grab one of those AOL 9.0 Optimized disks you got in the mail (come on, admit it. You were stockpiling those disks for years hoping for a use for them!)![]()
Jeremy
Brad B. said:Use old CD's (compact discs) as a sample surface. They are very sensitive to scratching and gives obvious results. Scratch one way with as uniform pressure as possible using a foam applicator or finger.
jgv said:This means:
I make one pass on a new CD with either the foam applicator or the finger with product. If it scratches it has abrasives, or
I scratch the CD and then see if I can remove it with the product?
(just to be sure what you mean).
Inzane said:Hmm, I thought the "CD scratch test" was for testing if a buffing cloth or drying towel would scratch a surface...
So it can be used to test a product as well? Guess I learn something new everyday.![]()
