How to post pictures?
Carl Anderson
I'm computer illiterate and having difficulty figuring out how to link pictures uploaded to the gallery to posts. Could someone please explain this procedure to a near embicile. Thanks.
Carl, here is a step-by-step way:
1. Find the picture you want to post in the gallery, put your mouse pointer over the picture and click your right mouse button.
2. A drop down box will appear and you select (click on) Properties.
3. In the properties box look for the “Address (URL)�, it will look something like this: http://www.autopia.org/gallery/data/500/18318front_and_side-thumb.jpg
4. You want to copy this line. The easiest way is to highlight the text with your mouse, then right click and select copy.
5. When you are ready to put the image in your message click on the IMG button. This is located above the box where you are typing your message.
6. When the IMG box opens up place your mouse pointer in the text entry box, right click your mouse, select paste and what you copied in step #3 will be copied into that box.
7. After the correct text is pasted in the box just click OK and you’re all set. Repeat the above for each picture you want to post in your message.
Carl Anderson said:
Thanks for the help: very kind of you to take the time to help me.........
Glad I could lend a hand :wavey
Looks like you've got the hang of it now :xyxthumbs
Actually I fought the same problem a week or so ago and PrinzII was kind enough to PM me on what I was doing wrong.
Hey, and your car looks good!
