tenorplayer23 said:I was on the US Plastics site. Do you have a link or direction to the ship free coupon??
Also, since I have the Lowes buckets too (unfortunate that they aren't a little wider at the bottom) do any of the US Plastics buckets work? I'll check the measurements, but thought someone already had a model number figured out.
Thanks.
See ya. :wavey:
STL WRX said:I bought the buckets from lowes too! So I just trimmed the outside of the grit guards to fit.... now they work perfect!
agpatel said:Use code 57590 when you check out, it is only for UPS ground, but still save ya some money.
RustyBumper said:The translucent buckets from Lowe's are nice because they also have measuring lines on the outside.
mtdew456 said:Ah yes, translucent was the word I was searching for and could not come up with. I definitely like the buckets a lot though! They have been very durable and the measuring lines are a nice plus as well!
Rob22315 said:FWIW, the cheapest buckets I've found can be had at Firehouse Subs. Their old pickle buckets can be had for a $2 donation. It does take a little while for the dill smell to go away but it doesn't seem to transfer to the car.
tenorplayer23 said:Were those the 3.5 gal. or 5 gal. translucent versions?
I bought the Lowes white/5 gal. buckets (because I hate the HD "orange") but, alas, too narrow at the bottom. Who would have guessed.............
Thx.
See ya. :wavey:
mtdew456 said:I have the 3.5 gallon buckets personally.
Setec Astronomy said:Don't get fooled by the filling effect of pickle juice. Be sure to do an IPA wipedown afterwards.
Furd said:I ran into that problem too. All five gallon buckets are not created equal.
You and your ggs will have to take a road trip or two to your local hardware store(s) until you find the right size.
Rob22315 said:I rechecked my dill pickle buckets from Firehouse Subs. It turns out the GG's just barely fit, with some pushing, all the way to the bottom. They don't fit the Lowe's buckets.
I think I'm going to start saving the left over liquid in the bottom of my pickle jars and resell it as dill wet glaze. The REAL DWG. :woohoo:
