Foam Cannon Gun Lance attachment test
Mikeyc said:
It really just makes washing the car a whole lot of fun doesn't it?
Mikeyc, it is really not just fun but functional,
I sprayed the car with foam that
1-helped loosen the dirt on the car
2- stayed on the car long enough for me to clean the wheels with foam gun
and wash mitt and other brushes "so I took my time"
3- when rinsed with water it is was almost 100% except for lower panels that had tar on them.
I really like this attachment and it sure made my washing safer for the clear and
fun!
by the way, I used pearl 1z shampoo with it, and although this soap is not really foamy
when I used it with spray gun compared to Gold Class, but on the cam spray foamer
it really made allot of foam that made me surprised and I used very little in the bottle
mixed with softened+filtered water
evenflow said:
Just a quick question folks
Will this foam cannon..
Cam Spray 527100 - Foamer Attachment
Hook right up to my pressure washer
Or will i need to buy adapters?
The camspray foam cannon WILL work, no adapters needed. It'll screw on directly to your hose gun.
Only the Karcher's and other bayonet type fittings need the adapters pictured in the earlier thread. Good luck and post a few pics or opinions with your foam cannon experience.
Here is my current set-up with the foam cannon. I still use the Karcher PWasher that has the bayonet fittings so this allows me to change the foam cannon to the sprayer quickly.
I'm back to using the original gun/hose as the gun from LOWES was crap.
Sorry to bump an older thread, but I was wondering if the Cam Spray foam cannon would connect directly to the Troy Bilt 2550 PW I have. I see you guys say that as long as it doesn't have a bayonnet style gun it should be fine, but I'm not sure of the difference between the guns. Thanks in advance.
DITTO FOR YOU ALSO - see posts #44,45
Do all karcher pressure washers have the bayonet end? Even the gas ones?
Mine looks similar to evenflow's. It's Karcher G2600VH.
I don't think any gas ones have the bayonet end, I think that's reserved for electric ones.
So, if I don't have a bayonet end, then I only need the foam gun to make it work?
My Gun has a female screw on type end and the extension has the quick connect type end.
Look and check if yours fits any of these. This chart may help you :2thumbs:
Short answer, yes... you can either screw it on or (my preferred method) use the supplied quick connect on the foam cannon to switch quickly between rinse and foaming.
