Downsides of extra clear as i'm painting my project?
V_Eight
I wish I detailed good
There might be a few drawbacks to it that i'm unaware of, but I can't think of anything bad about shooting a few extra coats of clear when I go to paint my project.
I'm going for ability to correct the paint for years to come as well as zero orange peel, both of which will require eating away at the clear, so the use of extra clear comes to mind.
Thoughts?
What are you working on? What clear do you plan on using?
You can shoot 3 coats, sand it down with 600, let it sit for few days in the sun.
Then (clean/mask) and shoot 3-4 more coats. This is called a "flow coat."
And it's commonly done on show cars, using a good quality clear.
For materials and technique join here: SPI Users Forum :: Index
I see no drawbacks as long as you are keeping the contaminents to a minimum instead of covering them with more clear.
Awesome. Thank you!
I would be using duPont Finish Master IIRC. I'm headed to the paint shop now to look at Hot Huez swatches and will clarify what exactly my friend had in mind to sell me.
This will be for my seventh Mustang, this time crazier than ever.
So doing the "flow coat" as mentioned by flashtime?
David Fermani said:
No negatives as long as the prep work is good. It's a great idea. Is your shop on point with your suggestion?
I'm spraying it myself. Is that what you're asking about?
The clear is BASF Diemant line.
There is one drawback i can think of; and that is excessive film build
which be more prone to chipping. Especially if you're using a harder
clear meant for collision work. Not sure of the Diamont clear you have
in mind.
PM this guy (JimC): SPI Users Forum :: View topic - ransom's new bike
He does mostly bikes and flow coats all his work. Very knowledgeable fella.
Or BarryK the owner of SPI as he makes clears for custom/resto and
collision stuff.
Setec Astronomy said:
Ah...the ol' burnt orange...
It's BASF Carizzma Orange Pearl over White Base. :2thumbs:
Flashtime: Just like my last semi-show Mustang, the front bumper is the only thing that needed paint maintenance because of chipping, so i'm prepared to do that again with this one anyways. I might have to "clear bra" it seeing as I get the stuff dirt cheap.
OTG,
A clear bra is a good idea!
Here's a flow coat example. 3 coats of SPI Universal, sand 600, then 3 coats of
SPI MS clear. Clearing over sanded clear - with a good flow clear - produces
very nice results. And you either greatly reduce or completely eliminate
a phenomenon called "urethane wave." Important know regarding hig solids
clear... Also, basecoat/pearl coat are the weakest link in the entire job, so
it's a good idea to "activate" them by adding a bit of clear hardner.
The "speed shape" was just a test. The rear fender is gun finished as it sits
here getting ready to be sanded down and taped up for the flame layout.
Flow coated, sanded and polished:
More pics of project: Bike 2 pictures by zsolo - Photobucket
Good luck!
Flashtime said:
OTG,
Good luck!
I dont mean this to step on your toes or even in a bad way, just out of curiosity, but are those swirls in the paint where its reflecting the sunlight? Ive always had a fascination with custom paint jobs, just rarely get to work with a nice one.
Yes! 2 different clears; one super soft and the other "soft."
Even a wipe with a MF towel will swirl it (with the first clear).
The first pic of the fender (with the speed shape on top) is gun finish.
By all standards, this clear is super soft; polishes out much easier months/years
later. The last pic, with the flames, is also soft but not as soft as the first;
same manufacturer. Next door is a commercial wood shop and dust is constant.
Here's the latest job with the same clear. Also with some slight swirls
but good enough to let go as is.
SPI MS clear (the soft clear):
My old bimmer. Sold 2 years ago. Bazillion passes with Ultrafina...
SPI Universal clear (the SUPER soft clear):
Transtar Euro Clear; a production clear that's somewhat soft but MUCH
harder than the clears used above:
Action!
My handy dandy "lip" tool:
These aren't exactly "production" clears used in body shops, they are
designed and better suited to custom/restoration jobs. Different characteristics...
I know, it's not quite up to "Autopian" standards...But it's good practice.
I figure, if i can polish out an ultra soft clear, even to this level, then
i can polish out anything.
While this is true (I owned a Black S2000, which is notoriously soft as well) Ill have to say now that Ive been doing this a while and with a DA machine, the soft clears are an easy task, while the new german clears are what kicks your butt now!:waxing:
