neighborsenvy
Found this listing on ebay.
WATER FILTER DEIONIZER RESIN AND HOUSING - eBay (item 110604582769 end time Mar-27-11 11:18:08 PDT)
It says it contains 1 cu foot of resin. Also says that it has a 1/2' thread on the top and bottom. When it gets to my house Im going to see if I can get an adapter for a garden hose. If that works I only spend $105 for this. If using an adapter doesnt work and I need to go the filter route the twin 20" x 4.5" housings are around $125. So the max Im spending is $230. Not bad for a CR like system but with enough resin to exhaust the resin 3 times before I have to recharge.
Hope this helps someone out.
