Clearkote Red Machine Glaze VS. Chemical Guys EZ Glaze?
Thoughts, pros, cons?
I have both and plan on using them but just wondering which is better for each task.
One give a better finsh one have more fillers?
Also can I layer a sealant over CGs glaze?
How should pinkmoose be used? For light swirls and imperfections?
thanx!
Diesel you can use sealants over CG's glaze its acrylic like ajt
use rmg under souveran and our purple wax
ok cool I was wondering that, cause of the damn maxima I wanted to see if the glaze would help before applying AJT
thats what i was gonna guess
I noticed you use top coat and 2180/1000p alot what makes you decide on what to use?
I noticed you use top coat alot what makes you decide on what to use?
Ease of use.
I for one can't polish these darn bmws.. :buffing: :buffing: :buffing: I mean hard clears fast enough. At that point I just want something that is fast & easy to use.
My first choice is always 2180/1000 due to durability although top coat is 6 to 8 months.
How does te CG Acrylic Glaze compare to Danase Acrylic Glaze? Does CG has some slight abrassive quality like RMG that makes it a good final polish as well? And can you top CG with Danase Glaze?
