Cleaning a shower
I finally attacked the shower stall today with my ROB to remove the hard water spotting and soap scum. I had an old yellow pad that was ready for retirement so decided to sacrifice it here before throwing it out.
First I attacked the glass enclosure panels with baking powder which made a strong dent in the spotting, but still left visible traces. I escalated at that point to using Bartenders Friend and that made another significant improvement; it`s not perfect but I can live with the faint hazing I see when looking at it in the right light.
Next I attacked the fiberglass shower enclosure walls themselves with the same Bartenders friend, but limited myself to one horizontal pass and one vertical pass so as not to overdo it and risk burning through the surface gel coat. That seemed to work well after I gave it a good rinse.
Once the shower walls dried, I applied a light coat of FK1000 by hand and buffed it off. Don`t know how long it will last, but for now it seems to be repelling water and beading. If it lasts 6 months to a year I`ll be happy.
Thanks, Nick
I finally attacked the shower stall today ..[and]..Once the shower walls dried, I applied a light coat of FK1000 by hand and buffed it off. Don`t know how long it will last, but for now it seems to be repelling water and beading. If it lasts 6 months to a year I`ll be happy.
Ah, if you get a chance to post back after a while, I`d sure like to know how the FK holds up under those conditions. I gather you have fairly hard water...
We used nanocoat first up on the glass screens. Yes still get water marks but easy.to wash off. We also squigee off excess now.
Sent from my SM-A530F using Tapatalk
My basement shower was bad, I mean really bad. I went the chemical + agitation + scraping route - at first, but it was very labor-intensive. I was using a home-brew of 3 ounces of TIDE Laundry Detergent + 3 ounces of Purple Power APC in a 32 ounce spray bottle. It did an awesome job of softening all the soap scum build up (after soaking for a while), but the agitation/scraping was still a bear in that confined space.
That`s when I remembered the laundry room sink has a faucet with GARDEN HOSE threads on the end. So, out to the garage I went and returned with my "spare" hose. Hooked it up in the laundry room, drug it into the bathroom and attached a good spray nozzle to the end. Turned on the hot water spigot and blasted the softened mess with a stream from the hose.
It was SO STUPID how well that worked. 95% of it was gone in seconds (it had taken me 1/2 day the day before to get less than 50% of the shower clean) - if I had only remembered the laundry room faucet the day before. BTW ... I DID get some water on the (concrete) floor, but a bath towel put down before hand took care of it.
Once all the `heavy` cleaning was done, I liberally sprayed TILEX over every surface and let it dwell, then took a wet, demoted microfiber towel and wiped it all down. Then after letting the TILEX soak for about 20 minutes, I rinsed it again with a spray from the hose - this time with the shower door closed - I just reached over top of the wall and sprayed it down from above, and all the water stayed IN the shower stall. The whole shower was now perfectly white and glistening - even the glass door was crystal clear.
Now, so that I never have to experience THAT again, once a month, I hose it down with TILEX and wipe it down with another demoted microfiber, give it a few minutes, then rinse with the hose (which is STILL hooked up to the laundry room sink).
TILEX sound worth looking into, ill have to give it a try, I have been using chemicals and this type of car wash mop,, the mop is easy on the back and easy on the shower surface.Screenshot 2023-02-24 at 5.30.48 AM.png
TILEX sound worth looking into, ill have to give it a try, I have been using chemicals and this type of car wash mop,, the mop is easy on the back and easy on the shower surface.View attachment 38077
Mine was so bad, a soft mop like that wouldn`t have touched it. I had to use a Scotch-Brite (coarse) pad and a plastic putty knife - until I remembered the garden hose attachment in the laundry room. You`re right about hand-scrubbing being hard on the back though, especially when you have as much hardened crud as I did.
Now that it`s been completely cleaned though, maintenance is EASY! Spray down with TILEX, allow to soak, WIPE DOWN the shower with a damp cloth (NO heavy scrubbing), just a light go-over with the cloth (MUCH easier on the back) and blast it with the garden hose and hot water - DONE.
Don- Glad you found a good solution! Just thinking...considering all the [stuff] you`ve flushed down that shower`s drain, I think I`d treat it with one of those "fix the slow draining" products. IME the generic ones work fine, my current jug is Target`s Up and Up brand "Clog Clearing Gel".
Way ahead of you. I used 1/2 bottle of a VERY thick drain cleaner - don`t remember which one - let it set for an hour, instead of the recommended time, then BLASTED THE SNOT out of it with the garden hose at full blast.
Yes, I know this post is old ---
Robot or human?
If your shower is Clean, and you spray this After you get out, and it`s ok for the water to be on there, it will help keep the shower areas sprayed clean.
Then, when you take a shower next time, all that spray just rinses off the shower.
Then, after, you spray it again.
Keeps the glass and white fiberglass panels,, etc., all clean for years...
Dan F
Resurrection of this old thread...
New house.
Porcelain tiles with fiberglass/acrylic tub/pan.
Can I ceramic coat the tiles?
What about sealing the grout?
Can I clay bar the glass and ceramic coat that also?
Dan, someday you will buy and use an inexpensive STEAM CLEANER to accomplish what your hot-water garden hose has done.
No, I do not have one, BUT my wife's niece bought a "cheap" one on Amazon and cleaned an up-north cabin shower that had hard-water built-up on it, and she said it turned out fantastic! Her regret was not buying the upgraded, better one for more cleaning power.
I think I need to start a new thread topic on STEAM CLEANERS and ask how many Autopians have one, what make and model it is, and how do they use it on their vehicles they clean AND for around the house cleaning.
Erman:
That Gel-Gloss is what I use on fiberglass showers and Formica countertops .
Works well, but not for cleaning. I think of it as a Last-Step-Product (LSP) for such home surfaces after they have been thoroughly cleaned by other household or car-care products.
By the way, the company that makes Gel-Gloss, TR Industries, make (or made, past tense intended) a great car-care product called TR Resin Gloss back in the late 1970's. It came in a silver and blue rectangular 16 ounce tin. It was the recommended product by Datsun (later to become owned by Nissan) for their cars. Having a used maroon metallic '77 Datsun 280Z back then, it is what I used on that vehicle and it worked well. This was about the same time that DuPont came out with Rain Dance and Turtle Wax came out with its Poly-Shell System. I used a Coral Blue product called Blue Poly One -Step Sealant on the 280Z than was light blue-green in color and had a parrot printed on the outside dark blue rectangular tin. Ah, care-car nostalgia....that is was happens when you get older and reminisce about the good ol' days.
Lonnie, Lonnie, Lonnie...you and your nostalgia.
First of all, they seem to still make TR-3 Resin Glaze, if this is what you were talking about: https://www.bluemagicusa.com/12a-6-tr-3-resin-glaze/
I also was a big 240/260/280Z fan back in the day, but I never got to own one (and IIRC it was always Nissan, they were just squeamish about using that name here in the US, so they made up "Datsun".)
I used to work with a guy who had a dark metallic blue Firebird, and he used to wax it EVERY WEEK with Blue Poly, he told me I should try some, I don't remember if I ever did. I always thought I would run into him on one of these detailing forums, but he's gone now, RIP TC. He used the liquid in the bottle, IIRC.
Setec:
Thanks for the "correction" on the TR-3 Resin Glaze and Datsun/Nissan name.
What I remember about the Blue Coral Poly Sealant is it seemed to have aluminum abrasives in it and the foam applicator would become the color of the single -stage paint you applied it to.
Maybe that was just the way single-stage paint was in the late 1970's.
Yes there are a lot of car-care products from the late 70's/early 80's I used, and some of my favorites were:
1) The Treatment Carnauba Car Wax that came in brown tub and a pre-cleaner that you really had to buy with it.
2) The Lazy Man's Wax that came in a yellow plastic tube and it was a powder you applied with a wetted cloth and then wiped off- no need to wash your car. Worked great on my white '83 Subaru GL-10 Wagon to remove fly specks, since I lived near a dairy farm in those days. Still have half a tub of it I used on gas stove grates.
Both the Treatment and Lazy Man's Wax came from the Iola Car Show held annually in middle Wisconsin in the second week in July.
3) Classic Car Carnauba Paste Wax in a black round tin. $4 on clearance at Kmart. BEST car wax in those days for what I paid for it. The 16 ounces of wax lasted about 4-5 years, but I cannot recall how many applications I got out of it; maybe 20?(Yes, I waisted wax back then.. thick is better!) Still have the tin and keep sprayer can nozzles, plastic bottle screw tops, and screw flip nozzle tops in. Yes, I do use them when something happens to one of the top nozzle types. Horded junk to some, until you need one!
