Dan
Well-known member
Just because it beads water, it does not mean your paint is protected!!!! Freshly polished paint with no LSP beads water just like freshly clayed paint beads water!
SuperBee364 said:OK, I've held my tongue regarding my claying opinion(s) for far too long... every time you use clay, you mar your paint. ..(sorry, Accumulator, I think I might actually be disagreeing with you on this point!) you can clay gently enough to leave your LSP intact, I say you aren't claying, then, because if you are using clay to remove contaminants you can't otherwise get off, you are rubbing more than hard enough to remove even the toughest LSP....
salty said:I am going to take the civil road and say I agree with both of you.
The mildest clay I have would be hard pressed to marr a clean well lubed surface, that said it also has no real use because it doesn't remove hardly anything.
Step up to a clay that can remove a contaminate in timely manner and yes there is some marring going on.
Personally if i am going to clay a surface it is going to get polished after.
salty said:..The mildest clay I have would be hard pressed to marr a clean well lubed surface, that said it also has no real use because it doesn't remove hardly anything..
Accumulator said:Well, I'd debate the "no real use" part, but you're right about it hardly removing anything; this is *NOT* real "decontamination" I'm talking about. Rather, it's just getting stuff that my oh-so-gentle wash regimen can leave behind (yeah, there're a few debatable issues there, huh?).
