SilverCivic
I just got some clay from Griot's Garage and tested it out tonight. I first washed the car with ONR and then after drying proceeded to attempt to clay the car. I cut off a piece of clay, folded it into a paddy and worked it back and forth using ONR (2 ounces to 1 gallon) as the lube.
The paint had absolutely no change in feel or look after claying and the clay had no containments on it. What am I doing wrong. The temp in the garage was probably a few degrees above freezing. Would the cold make the clay totally ineffective?
Any ideas? I was hoping to make my paint super smooth.
Thanks, Josh
Thanks, Josh
