Before and after, road paint and tar on blazer
Looks like you got it all! I normally use Tarminator to break it down then go over it with regular Moose Wax.
Labster said:
np, you should try Pro-SOL by prowax.com it is the easiest tar remover that I've used.
I just pulled up the website and noticed there is also a product called power-sol. Have you used this product and noticed any difference between the two. Just curious since you've used their line of products.
Nick
that damned epoxy paint is my greatest fear...it can be nearly impossible to remove....it's designed to be like that.:mad:
GSRstilez said:
What's with all this tar you're working on? :)
Is it polished in the after pic?
In the summer they do a ton of sealing the roads around here.. Yes it AIO'd and S100'd in the after..
Ya road paint is a big PITA to get off.. Took me little ore and hour to remove bugs, tar and paint from the blazer...
Antonio Wright said:
I meant for the Tarminator. ;)
oh lol...
I use a folded MF, and try to rub as lighty as I can and still get the crap off.
and yes I only use my MF's that I use for tar for use on tar.
I like those bug scrubbers but I cant stand to use them on paint...:nono
Nickshades said:
blazer looks good.......what kind of tire dressing do u have on there?
Nick
It is the ole Armor all, It is alittle wet when that pic was taken, I havent even wiped it off yet..
Nice work. The first time I saw the first couple pics I couldn't even bear it. The last car I detailed for a friend, I offered to do so when I hadn't even see it in the light. Unfortunately the car ended up looking like your first pic, only all the way around the car. I wanted to torch the car because it was such a frustrating experience.:angry Now that I can actually bear the sight though, you deserve a pat on the back, the blazer looks great.
