Advice on filling swirls, will this process work?
Original paint. Does Poorboy`s make a product that would clean the AIO off the paint without affecting the clearcoat? I really don`t want to remove any of the clearcoat, I would much rather fill the swirls then seal, which is why I bought BH and EX to begin with. Thanks!
Professional Polish
Polish w/ Carnauba .. is like AIO on steroids ;) but will work with the Black Hole
Polish w/ Sealant
all of these are non-abrasive and all are available at the Autopia store :)
Professional Polish
Polish w/ Sealant
Thanks, I noticed the Poorboy`s polish w carnuba - Poorboy
OK....just so I don`t screw up again. If I get the Polish w/Carnauba, I wash the car, then apply the polish THEN apply the Black Hole THEN apply the EX sealant THEN top with Souveran?
All that and I`m good?
you got it !! and then reapply the Souveran as needed ;)
You forgot the last step. Submit a "Wax-Waster" membership application to Ron. :)
Good luck!!
Poorboy`s SSR1 is slightly less abrasive than Poorboy`s Polish with Carnauba. Would the SSR1 be ok to remove the AIO? I ask cause I like the idea of it being less abrasive plus the store has it on sale right now
I like SSR1 :) But it does contain *light* abrasives, whereas Polish w/Carn does not contain abrasives.
Professional Polish
I`m still scratching my head on this. For ships and giggles, I went at some sanding marks with PP and a yellow BOSS pad. I was shocked. Still scratching my head.
why are you shocked? and shaking your head
<<<<<<<< :confused:
Because I just had a donut!
Well, I was just curious to see how a NON-abrasive polish, coupled with a polishing pad (not compounding) would do against sanding marks. I mean, it`s not an aggressive combo like SSR3 and a heavy cut pad, so I wasn`t expecting *those* results! AND, on top of that, I think the sanding was done at either 1200 grit, or 1500.
I was pleasantly surprised, to say the least :)
Another question: I`ve read some here and elsewhere that suggests that Natty`s Red paste enhances metal flakes in red paint, is that correct? I saw some people suggesting that Natty`s Blue muted their flakes, so I am more interested in the Red if it would enhance the flakes.
Also, I assume I could layer Souveran and Natty`s Red as the topper?
MarkCollier- I dunno if you`d want to add Souveran to the mix if enhancing the metalflake is part of your goal. I wouldn`t top [some product] with [some other product] anyhow...I`d just use *one* product that does what I want.
Thanks, I`ll just get some Natty`s Red and compare look to Souveran and see which I like better.
You could original Natty`s too ... there was a side by side test by an old member named Deanski .. he came to our Detail Weekend with his red car done half with Souvern and half with Natty`s .. only a couple people could guess which was which :) I like Liquid Natty`s Red for the most pop in flakes ;)
You could original Natty`s too ... there was a side by side test by an old member named Deanski .. he cam to our Detail Weekend with his red car done half with Souvern and half with Natty`s .. only a couple people could guess which was which :)
Interesting that *anybody* could tell which was which!
I find Souveran gives varying/inconsistent results on metallics; it *slightly* seems to mute the ss lacquer metallic on my Jag (which I *LIKE* as it`s a metallic gray not a silver) but it does *not* mute the flake in b/c Audi silver.
