Wire wheel acid trigger sprayers?
Matt1
Hi all,
Was wondering what type of trigger sprayer people use here to apply wire wheel acid (hydroflouric acid based)?
I purchased a few of these Tolco ones, but unless I have a few defective ones, they only seem to work once: (even the standard sprayers would hold up for a few uses)
Model 320CR "The Chemical Resistant Trigger"
Any advice would be appreciated.
Thanks!
I've used 100's of these triggers and they will last alot longer if you spray some APC through them after using acid. It will neutralize the acid and won't kill the trigger. The best, longest lasting sprayer made is the gray one made by Spraymaster. It has a 5 year warranty and I've used it for solvents, acids and everything else. If it stops working, send it in for a free replacement. I have one that I have 1 that I've been using for tire dressing for the last 10 years!!!
Here's the link:
Spraymaster Spray Bottle, Horse Supplies, Equine Supplies
usually the grey triggers are the one's you want to use since they are labeled as the chemical resistant ones, but eventually will wear out since the harsh chemicals will eventually take it's toll. the one DavidFermani mentioned, can be found at smart & final in the janitorial section where all the sprayers, sprayheads, trash bags, etc, are. iirc, it was around $6-$7...
edit: just called smart & final and it's $5.49...
Best thing you can do is, when you done spraying. Turn the bottle upside down and spray the last of it out of the sprayer. This will make them last longer.
Here's the link:
I appreciate the repsonse David! There is actually a Dover Saddlery retail store local to me, so maybe they stock these? I will try running some Simple Green through them after use.
