(Wife) 2012 Hyundai Tucson
xtremekustomz
So here are some shots of the damage on the front end. I think she was going 5 mph max. Totals came up to $5,700. Replaced hood, both fenders, both headlights, ac compressor, radiator support, bumper bracket, bumper, cowl, air dam undercarriage and misc pieces.
New panels had some dents in them so I pulled/filled those, sanded "ecoat" with some 320 and primed over filler areas.
2 Coats of House of Kolor KD3000 mixed as a sealer. I used the Devilbiss Pro Lite with a 1.3.
Sherwin Williams ATX basecoat. It covered good enough in 1 coat but I put a second on anyway. I used a Sata 3000 rp with a 1.3
And the Sherwin Williams Dimension DC5020. 2 Coats. I got the IR heaters out to speed up the drying process for all three paint steps. I used the Sagola 4500x with the 1.3 clear cap for this.
Should be doing bumper and grille tomorrow.
I started with some 3m Trizact 1500 on the DA. I mainly did this so it would be easier to see all the dust nibs that I needed to sand/buff out. As you can see there were lots of them. I sprayed this one in my garage and have to have the door open for ventilation so I was expecting this. After the 1500 I used some 2000 grit wet on a stir stick to sand each nib out by hand. I followed that up with some 3m Trizact 3000 grit over the whole hood. I buffed with 3D AAT Compound with a 3D wool pad followed by the same compound with an orange foam pad to remove the swirls left from the wool. I finished it up with some 3D HD Polish on a white pad. All done with a rotary. My microfiber left some small marring as seen with the light shot. It's going to get swirled up the first time my wife washes it anyway...
Pretty much got her put together. This new clear is SOFT. Doesn't take much to mar the finish. Hopefully it will harden up a bit soon. I still need to buff the whole car but it will have to wait because I have a few more paying jobs coming up.
Not sure why my camera lens keeps doing this. I have cleaned it multiple times.
