Quote: TOGWT -
You're the first Autopian I've heard that is using it - I've read many recommendations for this product but not one user.
The cost is $$ but if it does what is says, I'd be interested in buying this $$ metal sealant.
Love to hear more details on application, longevity, etc.
ZoopSealâ„¢ (Zoops Products Inc) is a three-part metal cleaning system that comprises: Zoopsealâ„¢ (parts A and B) Zoopsealâ„¢ Cleaner and Zoopsâ„¢ Final Seal
The Zoopsealâ„¢ Kit contains enough product to clean four wheels and the vehicles engine (75sq. ft.) Pre-polish surface to remove any scratches before applying as this product will seal in any existing surface defects.
ZoopSealâ„¢
a) Pre-Application:
1. Pour the bottle Part âہ“Bâ€Â� into the bottle marked Part âہ“Aâ€Â� and shake to mix thoroughly, allow the mixed products to blend (1-3 hours)
2. If you donâ€â„¢t need to use all 4-onces of
Zoopsealâ„¢, mix (exactly) ¾-ounces of part A to 1-ounce
of part B, and shake to mix thoroughly, allow the mixed products to blend
3. Mixed contents are highly flammable so keep away from any naked flames
b) Application Methodology
1. Use a 15:1 dilution
Zoopsealâ„¢ cleaner / distilled water solution and clean surface with a 100% micro fibre towel, repeat as necessary to ensure surface is thoroughly clean.
2. Thoroughly dry area with a clean dry towel ensuring that there is no water left on the surface, uncured Zoopsealâ„¢ is not miscible
3. Spray a light mist of Zoopsealâ„¢ cleaner (8oz spray bottle included in kit) on the polished surface to a dry surface, wiping in one direction only until surface is covered. A transparent rainbow coloured film will appear this is normal, until product is dry (2-24 hours) to the touch
4. Remove residue with a clean dry cloth
c) Zoops Final Sealâ„¢
1. Apply a thin light coat (polished parts only) and buff to a shine (do not allow to dry completely before removing)
2. Do not apply Zoops Final Sealâ„¢ to non-polished surfaces; it is for use on polished surfaces only.
3.While Zoopsâ„¢ Final Seal is still wet start polishing off the product, using light back and forth one-directional motions until product is no longer visible and lustre appears.
4. If needed, Zoopsâ„¢ Final Seal can be applied multiple times to produce a deep shine
Maintenance- clean surfaces with car wash concentrate/water dry and buff surface with a clean, soft mico fibre towel
Durability- 6-8 months dependant upon environmental and driving conditions
JonM
