Kotsios
Opinions please.
Micro-Marring - Tick-Marks - DA-Haze
These three terms are pretty much the accepted terms for a scratch pattern left in some paints from the oscillating and rotating action from a compound or polish and a buffing pad when applied using a DA Polisher.
Unlike Cobweb swirls or Rotary Buffer Swirls, the scratch pattern instilled by a dual action polisher is made up of millions of tiny scratches, some are curved or circular but some are straight, like a small tick mark you would make with a pencil if you were keeping track of a count of some type.
Tick Marks are a sign that either the paint is on the soft side, so easily scratched or the pad and compound or polish you're using are too aggressive to finish out without leaving a mark.
In most cases Tick Marks can be removed by re-polishing with a different pad and product combination.
Accumulator said:Different people are gonna see this differently (gee, sorta-pun).
IMO the "micro" means "not readily seen with the naked eye", the sort of stuff that the "average non-Autopian" wouldn't notice at all.
Accumulator is saying you can see micro marring, you are saying something different, you are saying if you see it its swirls if you can't see it with the naked eye and need a magnification device its micro marring.Dan said:We're on the same page for once!ound: I concur, micromarring is a condition that impacts gloss, but is not readily seen with your eyes. If you can see it, its swirls.
The above AG shots... in my book, swirls (granted machine generated). I could QD dirty cars and keep my finish "AG micromarring free"...lol.
Dan said:We're on the same page for once! I concur, micromarring is a condition that impacts gloss, but is not readily seen with your eyes. If you can see it, its swirls...
lkotsios said:Accumulator is saying you can see micro marring, you are saying something different, you are saying if you see it its swirls if you can't see it with the naked eye and need a magnification device its micro marring.
lkotsios said:For me the example that rasky pictured is borderline micro marring and swirls somewhere in between.
Any sort of surface imperfection that impacts overall gloss, but not big large enough to be identified as another sort of defect ie fine swirling, sand blasting, chips, etc. It is one step up from general haze.
RaskyR1 said:Reading the above you are basically saying that the super fine "micro marring" installed into the paint by a rotary buffer is the same as the super fine "micro marring" instilled into the paint by a DA. I strongly disagree with that and feel they need their own classification, just like "Pig Tails" and "Tracers" have their own term. While they are all defects in the paint, it's necessary as detailers to understand the difference between them.
We as detailers also need to start agreeing on a standard for these terms that get thrown around so loosely, which is exactly what Mike P has attempted to do in the thread I posted above....(and he did a great job at it too IMO). If we continue to use these terms so loosely, people like the original poster are only going to continue to be confused and also makes it more difficult do diagnose issues that people are seeing in their paint.
Can you please explain what haze is?Dan said:Rasky, I wouldn't categorize pig tails or tracers as micromarring as those can be seen AND diffrentiated from a general condition that impacts gloss. Also both pigtails and tracers require a much more agressive polish to remove than micromarring.
By no means is this a complete list, but going from worst to least:
RIDS
Sanding Marks
General Swirls
Pig Tails
Hologramming
Micromarring
Haze
And I completely agree, we need to standardize these terms and levels.
RIDS
Sanding Marks
General Swirls
Pig Tails
Hologramming
Micromarring
Haze
lkotsios said:Can you please explain what haze is?
RaskyR1 said:Edit: I also hope you don't feel I was singling you out by quoting you....it simply made for a good example.![]()
