What are your new favorite detailing products this year?
Bunky
Detailing Gnosis
Here are some products I acquired in 2012 that have homes in the arsenal.
Blackfire Midnight Sun Paste
I chose this based upon a recommendation from Jim (Dr. Oldz). It did not disappoint. It darkens paint (makes black look black), adds a ton of gloss, top tier slickness, and surprisingly durable on my truck parked outside 24x7.
It is a breeze to apply and remove: Basically, wipe on, no need to haze, then remove. It sheets well, beads great, and cleans easily. It also seems more resistant to bird droppings.
This my favorite paste so far but just rediscovered pastes them especially since I started doing all lsp application by DA.
Blackfire Microfiber Cleaner
I have been a long time MicroRestore cleaner user. I was getting near the end of a gallon so tried Blackfire given the positive talk. My process was usually two rinses with the second rinse including vinegar. Based upon feedback, I decided to skip adding vinegar with BF.
So far, I have not seen a need for using vinegar any more. I did not see the miracle stain removal like one review on some soiled towels but still works well. The recommendation usage is 2x microrestore so definitely not as cost effective but the results are better (based upon 5 loads so far).
Poorboy's Bold n Bright Gel
I have always had a place for Poorboys Bold n Bright dressing. It not only dresses but has cleaners as well so a nice one step product for detailing cars when tire is not 100% perfectly clean such as a quick maintenance detail or rinseless wash. The gel has the same milky white appearance as the regular but slicky thicker (tad thicker than Optimum Opti-Bond). When applied with an applicator it seems a bit shinier than regular BnB which can take 2 applications to get the desired look (evenness) on some tires. Bold n Bright Gel does it in one coat plus I prefer thicker liquids since I like to apply applicator to spread
Adam's Fire Hose Nozzle
I had tried one brand nozzle to see what the interest was but was not that impressed over my dial a spray pattern sprayer. The flow pattern not very good. However, the dial sprayers I have been using cost around $10 and start leaking eventually (sooner if dropper).
This was well hyped at you can guess where but quite expensive ($50). The Griots unit was even more expensive. Given I was about to spend money on another hand sprayer, I decided to try it. It worked a lot better that the first brand I bought so now my primary sprayer.
However, I had a chance to compare my old fire hose and the Adam's at a second location I discovered the reason. The Adam's works better with lower water pressures. My house has a whole house water softener and it really drops the pressure and waterflow (3 GPM max). The older model worked just fine the second location so I leave that one there. The only downside to this sprayer is when you put it down the setting drifts so you have to readjust plus unlike the pull trigger sprays you have to change the spray pattern by turning the head so less convenient.
Meguiars Glass Cleaner Concentrate
Of course, this has been discussed but I finally got a sample in trade. It has an addicting grape scent. My favorite glass cleaner has been and still is Sprayway.
Meguiar's is a very good glass cleaner, extremely cost effective, and does not have the strong alcohol content smell like some (thinking Stoners). It did not replace Sprayway but definitely use it more on interiors since aerosols can be messier (foam gets on all surfaces) and leaves that lingering grape scent, I mixed up the first batch with regular water but will try it with distilled soon.
Kranzle K1120T Pressure Washer
This is one of the best made products I own next to the Flex - both pricey and both made in Germany. It is all about good engineering. I really disliked my Craftsman gas pressure washer. The ergonomics were poor (just a pump on a two wheels, hard to attach hoses, move around), noisy (always on), and dealing with gas (carb, oil changes, extra season prepe) and just a pain to get out an use (did not store as easily in garage).
I have actually used it for non-detailing more than detailing (that was one of the rationales to spend the money for it but really nice to blast some wheels/tires much cleaner in a few seconds and rinse. You use a lot less water in a wash since it can rinse a lot quicker. It has to be at least 2x reduction in water. I expect to use it a couple times in the winter to do a pre-wash prior to a rinseless if it is cold outside.
I have not really had a chance to use the foam cannon yet but on the list for the next winter detail cycle.
Mothers Carnauba Paste Wax (Step 3 in Mothers system) - rediscovered.
I had this in the cabinet but only has used it once on a test spot several years ago. I tried it again after I used Blackfire Midnight Sun which re-ignited my interest in carnauba pastes. I have used this on several cars.
It leaves a nice hard glossy bright shine that leaves tight beads when lightly wet and sheets fast. It has done quite well on the truck outside under the trees.
It is a hard cake wax so it cracks so have to deal with the silvers but it comes in a large diameter metal container so easy to get a DA pad in to pick up a small amount. A couple swipes is enough to do a hood. It just needs to be applied thinly and removed very quickly (minimal hazing).
New for me this year
Speedy prep Towel - Time saver and worth ever penny.
Dynabrade da head for a rotary - Makes my flex 3403 a da on steroids.
m101 (wake up Meguiars).
Chemical Guys p40 polish - Thanks to the Chicago get together.
Garry Deans line of products (especially the Tire gel).
Collinite 845 and 915 - This stuff last and last.
BLACKFIRE polish & seal. i was looking to streamline to one step and this works perfect. i use it by hand. it just dissappears into the paint. great product.
BLACKFIRE polymer spray. BAM! perfect for maintaining that blackfire shine.
BLACKFIRE crystal seal. stands alone. my first jump into a WOWA sealant. so user friendly. never smears or streaks. great on glass too!
CHEMICAL GUYS new trim gel. great product! just a few drops on a foam pad and all your plastic trim will look great and be protected. this one caught me off guard.
Let's see, I did try a few that were very impressive....in no particular order
CarPro DLux
CarPro PERL
CarPro Ceriglass
CarPro Reload
Solution Finish
BlackFire Total Eclipse Tire Gel
BlackFire Microfiber Cleaner
Duragloss 105
Duragloss 601
Duragloss 501
Duragloss AquaWax
PoorBoy's World Black Hole
PoorBoy's World Spray & Rinse Wheel Cleaner
PoorBoy's World Spray & Gloss
Element 119
Wolf's Chemicals Body Wrap
Chemical Guys Citrus Wash
Chemical Guys Black Light
Chemical Guys V7 Spray Sealant
Gtechniq G1 Clear Vision Smart Glass
Adam's Car Care.
1. Car Wash offers a bucket full of rich, lubricating foam soap. I also like the one rinse capability of Adam's Car Wash.
2. Nozzle. I've experimented with quite a few and this one (which appears to be a Peerless) does everything as promised. Note: I did have to remove the excess lube to keep it set to position.
3. Wash Pads. The pads deliver a heavy load of thick foam to every panel.
All of the above have proven to be quality made, high performance products.
Glass Science
1. Glass Scrub. Gently massages away bugs, grime and other gunk from exterior glass.
2. Rain Clear. Somewhat difficult to remove, but once it's polished out it proves itself worth the effort and lasts over 6 weeks.
Tuff Shine
Extremely durable and just the right sheen for me. Although I do miss dressing the tires after every wash, I'll appreciate being able to skip that step this winter.
Products I'm not looking to replace and still believe to be the best performing sealant and wax.
Blackfire Sealant and Midnight Sun Wax. I've tried several others but always come back to the deep, slick gloss and protection I get from Blackfire.
Chemical Guys Bug Bogger
Pinnacle Bug Sponge
Megs M 205
Megs D 151
FK1000 Hi Temp Paste Wax
Pinnacle Signature Series II Paste Wax
Wheel Woolies
Hitachi Rotary Buffer
That products that I really love that I have bought this year is:
1: Nanoskin Autoscrubber 6" Pad...Super fast decontamition removel
2: Nanoskin Hydrophobic Nuba Wax....its goes a long way with only a very thin coat...Very good reflection and water does not like staying on this wax.
3: Nanoskin Express Spray Hyper Sealent...Very nice shine and adds even longer sealant time.
4: Meguriars Ultimate Hydrophobic Wax...I have been pleased with this product...very thin coat and it easily wipes off..no residue or dust..Nice deep shine and water repellant.
5: Griots Garage 6" DA Polisher...I love this DA. ( I cant say that with other Griots products that I have bought this year.)
I just got back into detailing this year.
New to me for this year:
CG V34, V36, V38
CG CWG
CG Honeydew
CG Blacklight
CG Jetseal
CG Ez creme
CG V07
Optimum tire shine
CG Hex logic pads
CG Pete's 53
Meguiar's perfect clarity glass cleaner. This stuff works great!
I'm sure I missed a few since I ordered a ton of items this year.
Those would be my main three; though technically I had both M101 and Garry's stuff at the end of 2011.
I would also add HD Polish, HD Speed, and my DWP849X to the list. Hopefully before long I can also add the Rupes LHR21E!
What impressed me the most about all the new products I tried, their performance was outstanding in all respects and NONE disappointed...:bigups
I have few product that I have tried this year that I am glad I now have.
BFCS: Super Easy to use, great beading, good looks
Foam Cannon: A pain to drag everything out and setup, but well worth it. You can defiantly see a difference from a foam gun.
WG Deep Gloss Liquid Seal: Super Easy to use, great beading, good looks
WG Uber Wheel Cleaner: Like IronX but a dedicated wheel cleaner that is more of a gel. Much better than Sonax.​
Not totally new this year:
Wheel Woolies: Good cleaning, less sling, solid made
ReLoad: My favorite top up sealant for coatings
Meg's D-110 Hyper-Wash: One of the best washes ever​
I've been using a few of Garry Deans products and I've liked them a lot.
BF Crystal Seal has been great. I really like how easy it is to use and how quickly I can do my truck.
My favorite that I have tried this year is Chemical Guys Black Light. Great stuff and I use it so much I bought it by the gallon and gallon goes a really long way.
WG Uber Wheel Cleaner: Like IronX but a dedicated wheel cleaner that is more of a gel. Much better than Sonax.[/INDENT]
Meg's D-110 Hyper-Wash: One of the best washes ever[/INDENT]
Hyper Wash is on my list to try.
Troy, have you used an all purpose cleaner like Optimum but find a dedicated wash like Uber wheel cleaner better?
In my opinion WG Uber wheel cleaner (WG UWC) and an APC are for different types of cleaning.
I can/will used a highly diluted APC for cleaning my wheels if needed on a regular basis. It will usually help to break down the dirt and such better and make it easier to clean. But an APC doesn't "melt"/interact with brake dust in the same way as WG UWC. If they are well protected though I usually just need soap and water.
WG UWC is more on the line of a stronger wheel cleaner/decon step IMO. It is more of a gel like P21S gel cleaner. So it clings well and keeps working. I even applied some to my already washed wheels and actually got some reaction and cleaning from it, showing that it wasn't as clean as I thought. Being that WG UWC interacts with the metal it is more like Sonax / IronX.
My upcoming review will show some more info and more of my thoughts.
