WHAT a DETAILER NEEDS to KNOW ABOUT DRYING.....
buda
A day does not go by that we are not asked by detailers "how can I get the carpets/fabric upholstery dry so the moisture does not stink up the interior?"
There are a number of solutions that could be offered.
However, I think you will find this article quite informative in considering the entire issue of moisture in the interior and how to remove it.
After spending a great deal of time and effort to get the interior of the vehicle clean the customer asks the inevitable question, "How long will it take to dry?"
Many customers, especially the auto dealer, ask because of previous bad experiences with detailers who have over wet the carpets/upholstery and left the car wet and stinky.
No question when you put moisture in carpets and upholstery it is going to take some time to dry, not just to the touch, but dry completely.
Any carpet/upholstery that is wet after 24 hours can be susceptible to microbial growth (mold). And that will create nothing but trouble for you and your detail business.
LOW MOISTURE CLEANING
When asked how long a carpet/upholsery will take to dry, your answer really depends on many factors, such as the method of cleaning; the skill of the detailer and big the vehicle interior is and what you do to help remove the moisture after cleaning.
The skill of the detailer is very important because far too many detailers simply "over-wet" the carpet/upholstery.
Now, low-moisture cleaning methods should, logically, take less time to dry.
LOW MOISTURE CLEANING W/ AN ANGLE
Many detailers today believe that low moisture cleaning isn't necessarily about how much cleaning solution is used in the process. They believe that low moisture cleaning can be performed with a good soil extractor. Low moisture cleaning isn't about the amount of moisture applied to the carpets/upholstery but moreso as to the amount of moisture residue left immediately after cleaning.
GETTING FROM WET TO DRY
You might have noticed that when you clean a 2 seat vehicle drying occurs faster then when you clean a van or a Surburan, say.
Why? The residual moisture in the large vehicle is much higher than you realize, even though you follow the same cleaning methods.
IT IS ALL ABOUT PHYSICS
I don't know about you, but I was never any good at Physics and I opted to take study hall as an elective rather than something like Physics when I was in high school.
In any case, like it or not, we have to understand Physics to understand something as simple as drying carpets and upholstery in a vehicle interior.
So here we go....Physics comes into play here, that is, high pressure moves to low pressure in a given area. What this means is that if you do not create an atmosphere in the vehicle interior so moisture can move out, you will not have as dry an interior as rapidly as you would like.
As you shampoo carpets/upholstery in the interior of a vehicle, you increase the amount of moisture in the air, and that moisture needs to be removed from the air so that the moisture you create in the carpet/upholstery can evaporate.
If the air is saturated, you cannot have effective evaporation.
So air temperature, relative humidity, dew point and vapor pressure all come into play when attempting to rapidly dry carpets/upholstery during and after cleaning.
WHAT YOU CAN DO
As mentioned, using low moisture cleaning is the most obvious step to insure rapid drying, simply because there is less moisture used in the process.
Regardless of the cleaning methods use, detailers seem to feel that if they create sufficient ventilation by opening doors and windows they can accelerate drying.
However, what has to be realized here is that if the outside humidity is higher than the humidity in the interior of the vehicle, exchanging the air inside with the air outside will not lower the drying time.
On the other hand, if the outside air is hot, low in humidity then it is quite acceptable to use the air exchange method of drying.
If this is not the case then you have to use some type of "mechanical" means of drying, ie, interior air blowers (dryers).
DRYERS
You need to have an air dryer that generates a great deal of cfm, a typical dryer should generate at least 2100 cubic feet of air per minute to be effective.
Another point to rapid drying is that when you finish cleaning the front carpets/upholstery in the vehicle immediately place a set of air dryers in the front area to begin the drying process. This immediately sweeps away moisture above the cleaned carpet/upholstery to allow more moisture to take it's place. If this does not happen the moisture in the carpet/upholstery stays in the carpet/upholstery.
Gosh, I never knew Physics was so easy to understand. (lol).
This is actually an Italian thing: It is called "Bernoulli's Principle," and basically means that airflow across a surface reduces air pressure, which allows moisture to move into that area.
Think of it in terms of how airflow creates lift for an airplane. The same principle applies to the drying of carpets/upholstery.
Hope this helps you understand the science of drying and results in faster and drier carpets and upholstery in your detailed vehicles.
Regards
Bud Abraham
DETAIL PLUS SYSTEMS
Nice article.
I have two air movers that get placed inside every interior detail I do, and they are left there overnight. :xyxthumbs
Nice. We also have dehumidifiers which pull the moisture out. They also do a great job. You can run them for a couple of hours, and you'll have 4-5 cups of water in the tray.
Barry Theal said:
Buda great article. Rasky what air movers do you use.
I use these. I like them because they are smaller than the big industrial ones, they can be placed on the back seats and tilted downward at the floor and you can plug them into each other so only one extension cord is needed. :)
Edit: I also places a foam pad and a paper floor mat under them to avoid leaving impressions on the seats....more important with leather seats probably.
Power dryers are great, but even standup fans will do just fine. As long as something is moving air around in the vehicle, it will dry as long the environment that the vehicle is in is dry.
good article.
Bingo! When I used to clean residential carpet that was the key to quick (2 hours) dry times.
IMO, if you're going to get a dryer specifically for drying carpets and seats (other than a normal standup $17 fan), go with the Xaact 360 degree air mover. I got to see this thing in action at this year's Car Care World Expo. AWESOME dryer.
Here is how I have my fans placed...having adjustable ones allows the air to be better directed at the carpet IMO.
The pre-sprays and rinsing agents you use on the carpet will speed carpet drying time too. I use a pre-spray with a PH of a 10 I know I need get the PH of carpet back down to a 5 or 6 range to speed up drying time, I rinse the carpet with a Acid rinse of a PH of 2.8 which leaves the carpet with a PH 5. I am not sure why bring the PH down to a neutral state speeds up drying times and if your applying a carpet protector it will preform better if the carpet is neutral PH too.
Good stuff Bud. Most of the guys that do dealer work don't take/make the time to return their vehicles with dry interiors. Recipe for dissaster.
Not sure where you are getting your information but a good carpet shampoo should have a pH of about 8. You say you need to get it down to 5 or 6 pH. I do not understand that.
On the pH scale 7 is neutral and anything above 7 is alkaline and anything below 7 is acidic.
I have never heard of a carpet shampoo that was acidic with a pH of 5 or 6.
You use an acid rinse on carpets to neutralize the alkaline. If you do not do that white carpets will turn yellow.
That is why white tee shirts; briefs and white shirts yellow after being laundered a few times. They need to be rinse with an acidic rinse to prevent yellowing.
Do not believe there is any particular reason to neutralize the alkaline in a dark carpet as it won't show the yellowing anyway.
Not sure you are correct about rinsing with a 2.8 pH acidic rinse as that might be too harsh on the fibers.
Will check out with my sources about pH and drying and let you know
Regards
Bud Abraham
Perhaps so, but since when is there white carpet in a vehicle ?
