Paulie Walnuts
Well the intent of this review is not to step on any toes just offer an honest persons thoughts who is an enthusiasts detailer and someone who details for cash whenever I want to but not every week.
Going in I was expecting a lot more power from the way that it was advertised and what the general reactions from the beta testers stated.
First thing I noticed is that its heavier, not much but enough to notice.
Second was the backing plate was way to small so put a larger one on. It vibrated so badly I wasn’t sure if I wanted to fix the hood with it and go to the rotary. So I went down to a 4 inch pad and a 2 ¾ inch backing plate. At that size it worked great but it covered such a small area that there was not a lot of use for it. So I went back to the backing plate that came with the UDM and used the 6.5inch LC VC pads I have always used. It was better than the larger 5.5 inch backing plate but by much. At one point the vibrations were so bad that I tried to take by wedding ring off and couldn’t get it off because my hands had swollen up. Anyone who says the vibrations are less than the PC I think you are crazy. To cut down on vibrations I put the handle on it but I just don’t like that feeling so I tossed it off after one panel.
The on / off switch is the biggest pain in the a$$. I must have accidentally turned the UDM on 4 times, I really hope a fix for this comes out. I like the way the speed dial protrudes from the machine, its easier to adjust speed. And the cord being shorter is also not good, even though I use an extension cord there are times where I am in a confined space and would like the extra distance so that I do not have to get out the extension cord.
In summary, don’t expect miracles, and I would not say that its going to remove rotary type swirls. I guess I was just expecting a smoother machine and I certainly did not get one. Its definitely better than the PC and will probably replace it but it sure did not live up to the hype I had read. If we could kick the power up another 20% and get rid of the vibrations it would be much better.
EDIT: Im a moran and can not spell. Yes I know moran is spelled wrong, its an OT thing.
