Triggered
Setec Astronomy
Well-known member
I think I have an old thread here at Autopia, or at least some posts (possible it was at AGO) bemoaning the lack of a small form-factor polisher (for ~3" pads) which would have the layout of something like a Flex 3401, with a trigger switch. Of course Flex finally came out with a small polisher, the PXE-80, which has a slide on-off switch. I had kind of forgotten about it until I dug up that Mike Phillips glass polishing video for another thread, where I came across another vid where he was using the "pixie" on some inside glass.
So I was looking at the polishers here in the Autopia Car Care store, and noticed that Griot`s has a similar machine, BUT WITH A TRIGGER. Going to the Griot`s site, all of their polishers have triggers, including the small DA`s (the one that`s like the "pixie" is a "hybrid", these machines along with the Rupes nano (which has a trigger) are convertible between DA and rotary).
It seems like Griot`s is the only company that got the memo, that power tools should have triggers. No one here has a power drill with an on-off switch. Not sure why almost all of the "PC-class" tools from Rupes, Zentool, Flex, etc. have on-off switches...maybe it`s a pricing constraint.
Who else thinks everything should have a trigger?
Triggers are good for short duration polishing but I really don`t want to hold onto a trigger for hours.
I`m all about (lockable) triggers.
This reminds me that I need to get rid of my Rupes Mini, which was too PC-like for my taste (got a GG unit to use instead).
Cyclo polisher are such a pleasure to use but you seldom see them mentioned today. What a shame
Cyclo polishers are the ONLY reason 4"diameter foam pads exist today. And , yes, I have them for use on my older Porter-Cable Dual-Action 7424 polisher.
Long live 4" pads!
On-Off switch and the thumb-wheel rotation speed control work for me, but that is because I am used to it on the PC-DA. Triggers are great for drills that are used for a short-time duration. Long-time duration usage, even with a trigger lock? Not sure; depends what you get used to.
How long do you really keep the trigger depressed when you are polishing a car? If you are doing a 2` x 2` section, as is frequently recommended, not very long. If you were doing a 30` boat that you had preapplied the polish to, then I can see it being a long time, but that`s what the lock is for. I mean how long do you polish a section on your vehicle? 2 minutes? I don`t hear anybody complaining "oh, I went around my car to hose it off (or pressure wash it off), and I had to hold down the trigger on my spray nozzle (or pressure washer wand) for 2 minutes, why can`t they make a spray nozzle with an on-off switch???" (yes, I`m aware there are shut-off valves etc. for that)
So, to your point, Lonnie, I guess it`s what you`re used to, if you are used to holding your spray nozzle trigger down, it`s no big deal, but if you have a polisher with an on-off switch, then a trigger is a big complication.
Cyclos look to bulky to get in tight spaces.
They aren`t right for every application. The tight spaces were generally less of an issue for me than certain panel contours, but eh, that`ll just depend on what the vehicle is like. I bought my first PC/non-Cyclo polisher when my Cyclo proved utterly unsuited to polishing my XJS. Before that, I never gave any thought at all to having a different polisher.
chevy- Heh heh, he might get hooked on that thing like I did! If nothing else, IMO it`s a great unit to get started with.
