rlmccarty2000
Active member
I tested three SIO2 toppers last week (BF SIO2, TAC Systems Quartzmax, and PA HighGloss). The BF SiO2 was the loser in initial beading, but after mulling it over it might have been user error, so I decided to give it a redo. This time I sprayed it directly onto the paint and then wiped off as opposed to spraying onto the microfiber and applying this way.
I changed up the lineup this time (variety is the spice of life). I kept BF SiO2, and added Britemax Remax SiO2, Gyeon Cure, and PBL Coating Booster.
The process was the same as the last time. Rinseless wash with McKees 914, clay (Nanoskin) with Prima Amigo lube, rewash with McKees 914.
After washing
Applied all toppers by spraying directly onto paint and wiping with a different microfiber towel each time. From left to right, BF, Britemax, Gyeon, PBL. They all look good and you can’t tell much difference except the Gyeon darkens the paint some.
First beading photo, BF and Britemax
Second beading photo Gyeon and PBL
After wipedown
Thoughts: they all perform well. All were extremely slick and I couldn’t tell any difference in slickness. I think the BF needs to be sprayed directly onto paint for best results as it is the thinnest of the four. Gyeon Cure was the worst of the four to apply and wipe off. It left hazing that I had to buff off 4 times while the others were a quick wipe off with no streaking. Cure is much thicker and the directions say to spray onto a towel and apply and I strongly agree here. I hope Cure lasts the longest or I would rather use any of the others.
I’m not sure how long these will stay on the car because it needs a complete wash. It stays outside 24/7 and we have 4 large pecan trees that put out a fine mist of sap (nasty). The wife refuses to use a car cover because “it’s too much work”. Lol.
I’ll be happy to answer all questions. I ordered IGLs SiO2 topper and will review that when time allows.
Sent from my iPad using Tapatalk
After washing
After wipedown
