shadow85 said:So an APC would work.... I was looking at the Griot stuff but was afraid it wouldnt work out with out a a session of good hosing off.
Accumulator said:I'd sure want to rinse any APC off, and thoroughly.
The Griot's Rubber Cleaner will also need rinsed off, but their Rubber Prep does *not*. Yeah, it's pricey for that little bottle all right, but *MAN* is that good stuff.
I just used it on the MPV's new tires...they were very messy from mounting and having been driven (really awful dusting from the pads I run on that vehicle) and I just wanted to ONR the wheels/tires. ONR did *NOT* do [squat] on the tires but the Griot's Rubber Prep was *perfect*, left 'em ready for Z16 in no time.
shadow85 said:So I can use a foam to wipe on the Rubber Prep and then go over it with ONR brush?
Accumulator said:You don't even need to go back over it with the ONR brush, just wipe it dry (it doesn't leave much behind to wipe anyhow) and apply your dressing. It's like some kind of "doesn't leave anything behind" product. Just leaves nice clean rubber, ready for dressing (or not, depending on the situation).
I did a quick wipe with ONR first, just to get the mud/dust/etc. off so the Griot's Rubber Prep wouldn't have to deal with that. The still-awfully-dirty tires just cleaned up like magic with wipes of the Rubber Prep. All the [soiling] just goes from the tires to the Rubber Prep medium (I used an old MF).
I didn't clean out the MF until I was done, just kept finding a clean section as I kept working (finally got out another one for the last tire).
I can't overstate how happy I am with this product. I don't use it all that often, but every time I do it performs to spec.
shadow85 said:Thanks. It sounds like what I am looking for. Have you tried it without drying ONR off first? Does it have to be dry for it to work??
dschribs said:The Griot's option sounds like a good solution. Will it help the white letters on the tires or no? If not, is there another option for them. Nothing works like Westley's Bleche White but it needs to be hosed off like crazy!
