thoughts on Finish Kare products?
dmxsoulja3
I've seen a few posts of people using FK 425 the QD, and mentionings of other products, can someone fill me in on what products they are using, I guess I'm a collector of products now that I've become an autopian and sometimes I just try certain lines of products on certain cars etc..I checked out their website and they offer a TON of products, anyone mention any highlights?
Thanks :waxing:
Really like 216 easy to use and leaves the paint nice and clean/shiny. 108 is very nice for the interior, 118 is a nice car wash, 425 is a great QD. I have a bunch of other's, but have not gotten to them yet.
Definite highlights from FK1:
- 425
- Pink Wax
- 1000P
- 215
- 216
- FX-100
- 360
etc., etc.
I have a LOT of faves from FK1, but next I want to try their new 336NG finishing polish, the 440 compound, the 300 hand glaze, and others...
I have used alot ot the fk stuff lately and I love there stuff! This is what I got.
118 car wash
1016 wash and wax( my favorite car wash ever)
121 ultimate cleaner
336ng high gloss polish
215 all in one polish
216 wet and slick claze and sealer(carnuba style)
217 glaze and sealant(my absolute favorite product!!!!)
2180 sealant
1000p high temp synthetic wax/sealeant(adds another layer of clear)
I absolutely LOVE FK's Pink Wax, it gives a glow that I find really hard to duplicate with other carnubas. Natty's Blue doesn't hold a candle to it looks wise, IMHO, and it also lasts quite a while. Smells like gasoline, PITA to apply by hand, but if you breathe through your mouth and apply via PC the results are great. It's hands down my go to on almost all my details now, the only other LSPs I find really worth using are Souveran on blacks and reds, and FK2180 on silver topped with Aquawax.
Here's a shot where I tried to capture the glow, it really does look better in person though:
My FK must-haves are
Pink Wax
1000p hi temp wax (not so much a must-have for me, hard to remove)
2180 (although right now I'm liking the Duragloss sealants)
FX-100
and my two absolute favs
146 and 425
I have been alternating layers of PW and FX-100 and topping weekly with Aquawax. Amazing!!
I also tried some of the glazes, 303 comes to mind but I really didn't notice any improvement. User error possibly?
Would love to hear from those who have used the 336ng finishing polish. Any comments? How much did it correct? What pad did you use?
The Fx100 spray glaze is nice, as is the 425 QD and the Decontamination kit works well, as does the anti-static car wash.
Haven't tried any other products yet, but I haven't heard anything negative about any of them.
I would speficically love to try all of their anti static products. 146 and 425 have completely changed my detailing regimen. I don't fuss with any pastes of any form so detailing takes two seconds and
my car is ALWAYS clean even though its parked outside 90% of the time. Rain melts away surface dust leaving a slick surface. Does it get better than that?
in the non anti static department pink wax and fx100 do pretty good job. I have 330 and 121 samples which I never tried.
I may have to ask for sample of 217 on my next order.
I absolutely LOVE Pink Wax, 425, 1016 and fx-100. FX100 had a learning curve, but once that was established I use it on everything from glass to paint.
I used 303 several times, and stil have yet to master it, as it has some cut to it (unusual for a glaze) but never seems to "buff up to a shine" on my PCeven at speed 6. Seems to have a forever work time. So I just make several passes with light pressure and then wipe excess with several passes (first for majority of excess) with a plush terry, then foloow up with slow smooth and even pressure wiping motions ("loving your car" as Mike Phillips would say). Overall it does leave the finish deeper, and masks any marring I may have.
using too much product? With glazes you only need a tiny amount
From FK, I've got Pink Wax, 2180, FX-100, 425, 146 and 121. Of those I really like Pink Wax and 121. I've used PW to top a bunch of different sealants and I really like the look. Still comparing PW with Natty's Blue and S100. I really like 121 and use it for the car and around the house. It works well as a degreaser near the kitchen stove and even to remove dirt stains from the jeans that I use when I go out to construction sites for work!
The sprays are just ok for me. While I haven't used 425 that much, I don't really see that it's anything special. It didn't dazzle me when I used it on my car. It did work well to clean and keep dust off of my tv screen. I use 146 to clean dirty door jambs and grime and water spotting under the hood. I used to use FX-100 after PW and on cars with EX-P, but I find that after buffing, there's a fine yellow dust that remains and gets irritating to clean up. Now I just use Crystal Mist or OCW. I still have about 3/4 of the original bottle to use up.
is that dust Carnauaba bits? I was in the same situation so instead of spraying the car or the towel I woud spray a foam applicator and spread evenly and thinly. Worked like a charm. FX 100 has given my Silver wheels the best pop so far and it seals as well to ward off brake dust baking away the clear coat. I also like that its liquid so its harder to miss a spot when buffing it out. Instant gloss.
yep yello dust...
I would get it all over my canvas top before I started applying it with a foam applicator.
Its the little carnauba bits that still stick to the inside of the bottle when its half empty.
This is certainly a product you have to be careful spraying, definitely not directly onto the car.
But worth the effort.
I ALWAYS spray it directly to the car, and never had any issues whatsoever.
drck1000, racingbeat,
How many trigger pulls do you use per panel? Do you let it haze? Please describe your routine with 425 & FX-100.
I should try your application method of spraying it on a foam applicator and then spread on the paint. FWIW, I didn't like the way that the FK1 sprayer would only put out a stream of product instead of allowing you to tighten down to a mist so I bought some replacement sprayers that are very similar to the Poorboy's one that can spray a VERY fine mist.
Yep, very fine yellow dust. I assumed it was that yellow gritty stuff that gets separated in the container when you've let it sit too long (like racingbeat noted). The best I can describe it is that the bottle looks like melted butter that you would use for lobster and has the salt and other lobster bits floating on top. Even when mixing for a long time, sometimes it leaves some of that stuff on the sides of the bottle.
Here's my routine for both sprays.
FX-100 - SHAKE WELL. I also switched out the sprayer to one that can spray a finer mist instead of the single stream that the FK1 sprayer would allow. I spray the same amount as other sealant or carnuaba sprays, which is probably two quick mists on half the hood of my car with each spray depressing the trigger only about half way, or even if that much. I then spread it around with a medium plush MF towel and by the time I'm done spreading around, it's pretty much worked in and almost dry. I then turn the towel over and then buff/wipe down the area. By the time I'm done wiping the panel, I notice slight traces of the fine yellow powder spread out and it seems like the MF towel is just pushing it around. I follow up wipe with another plush MF usually can get rid of the dust, but just another step that I don't have to when using products like Crystal Mist, OCW, HGAS (very different, I know), etc. I've tried both WOWO and wiping on and spreading around and then let haze and then buff. Get the yellow dust in both cases.
425 - About the same as FX-100, except that when I am spreading the product around, I doesn't "work in" as easy and will spread around for a while. After I'm sure I've spread it all around, I turn the towel over and it cleans up whatever product is left on the surface. Probably using too much product, but I am not trying to be precise on the amound that I spray on each panel.
Unless I get much better results from you recommendations, 121 and Pink Wax are probably the only FK1 products that I will continue to buy.
fx-100 on wheels is AMAZING. They really make my OEM alloy wheels stand out and does indeed seem to cut down on brake dusting.
