Swissvax Cleaner fluid and Zymol wax
rajrules
Hey all,
Just a quick question. Do you have to use Zymol HD Cleanse with Zymol waxs?
can I use swissvax cleaner fluid instead or another chemical cleaner that is easier to use?
Unfortuantely I've not used Swissvax Cleaner Fluid to comment on it's use under a Zymol wax.
However, you don't need to use HD Cleanse but, as a chemical cleanser and glaze, it contributes a lot towards the final waxed appearance. I don't know if you can buy Raceglaze products in the US but I've recently started using Raceglaze Signature Pre-Wax cleanser instead of HD Cleanse. It is a lot easier to apply and remove, gives similar results and leaves the surface nicely cleansed and glazed ready for your chosen wax.
Raj,
Zymol HDCleanse + Swissvax Cleaner Fluid:
1. Cleans the paint, prior to waxing
2. Polishes the paint to enhance glosss, prior to waxing
If you're using Zymol waxes, it is not compulsory to use Zymol HD Cleanse before applying the Zymol wax. Any equivalent product will do.
Note:
IMO, Swissvax Cleaner Fluid (which I use lots of), gives a much richer, sophisticated look.
After this, I'd apply any Zymol, Swisswax or any other carnaubas.
